Fuel hose not the same on DX engine as on the ZC? Help...
Old Apr 15, 2003 | 05:51 PM
FourthGenHatch's Avatar
Default Fuel hose not the same on DX engine as on the ZC? Help...
Today I disconnected the fuel line that goes from the Fuel Filter to the Intake Manifold on my DX. It is very similar to the connection between a brake like and the caliper, goes on a bolt with a hole on it. However I was looking at my ZC's fuel rail and I noticed it is more like a hollow bolt with the hole in the end. I don't see my DX fuel line connecting to the ZC. What line can I use? Anything with MPFI?
Old Apr 15, 2003 | 06:25 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Fuel hose not the same on DX engine as on the ZC? Help... (FourthGenHatch)
You can use the Dx line if you take a die grinder or drill press and enlarge the opening on one side or find one off of an Si or Hf.
Old Apr 15, 2003 | 06:28 PM
Default Re: Fuel hose not the same on DX engine as on the ZC? Help... (88DXCRX)
I will just use the Si one, do you think Honda stocks them? I imagine the rubber gets cruddy so maybe people buy them often enough.
Old Apr 15, 2003 | 06:46 PM
Ef Whore's Avatar
Of course Honda will have them, but in stock is the question. I hate ordering oddball parts from Honda they take forever to come in.
Old Apr 15, 2003 | 07:33 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">Today I disconnected the fuel line that goes from the Fuel Filter to the Intake Manifold on my DX. It is very similar to the connection between a brake like and the caliper, goes on a bolt with a hole on it. However I was looking at my ZC's fuel rail and I noticed it is more like a hollow bolt with the hole in the end. I don't see my DX fuel line connecting to the ZC. What line can I use? Anything with MPFI?</TD></TR></TABLE>
Finally someone else has had this problem, I'm pretty sure I had the same problem you have. I just drilled a hole in the fuel rail. Works great.
Old Apr 15, 2003 | 11:11 PM
markw's Avatar
Default Re: Fuel hose not the same on DX engine as on the ZC? Help... (Ef *****)
The DX fuel line bolts right up to the fuel rail on an Si, or ZC intake. Been there, done that numerous times.
Old Apr 16, 2003 | 06:20 AM
Default Re: Fuel hose not the same on DX engine as on the ZC? Help... (markw)
My problem was bolting it up to a b16.
innes887
Nov 19, 2007 03:30 PM
FalkenSiR
Feb 16, 2005 09:22 PM
Grease Monkey
18
Oct 10, 2003 03:02 AM
xvracing
Oct 3, 2003 05:53 PM
WhatThaFrig
Feb 23, 2003 11:23 AM
