Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
compensator arm bushing is seized.. anyone experienced this before?
Old Apr 15, 2003 | 05:47 PM
E-AT_me's Avatar
Default compensator arm bushing is seized.. anyone experienced this before?
removing all my suspension arms to throw on a prothane bushing kit, and low and behold, my compensator arm bolt is seized to my bushing in the componsator arm.. now, it can't be the easy one, that's attached to the trailing arm.. it has to be the one connected to the toe adjustment screw.. i know it's not seized on the bolt, i can loosen it.. but now it's bending the mount.. YIKES!!! anyone can help? and can i just cut the bushing off? but i don't want to bend the mount anymore.. i hate rust and pb blaster isn't working... neither is a big hammer.. i'm lost.. i love my CRX, but this is making me hate it... thanks in advance...
Old Apr 15, 2003 | 08:55 PM
Mike P.'s Avatar
25 Year Member
Default Re: compensator arm bushing is seized.. anyone experienced this before? (Rexman)
While trying to remove this bolt, are all the other bolts on the trailing arm still fastened? If the trailing arm is sagging a little bit, I can see you having some difficulty removing that compensator arm bolt, just due to bad alignment of the parts making them bind. Undo the compensator arm first, and move your way back, I'm thinking.
Mike-who had a "jolly good" time replacing compensator arms and trailing arm bushings this weekend.
Old Apr 16, 2003 | 04:44 AM
E-AT_me's Avatar
Default Re: compensator arm bushing is seized.. anyone experienced this before? (Mike P.)
nope.. everything is off the car except that one bolt.. fun, eh?
Old Apr 16, 2003 | 05:07 AM
Geezer's Avatar
Is the bushing turning in the compensator arm? If not, an impact wrench might bust it loose without bending the mounting, since it only applies rotational force, not lateral force like a breaker bar. If the whole bolt/bushing mass just spins, it may be time to get out the sawzall.
Old Apr 16, 2003 | 05:35 AM
Mike P.'s Avatar
25 Year Member
I'm thinking you should maybe attach the rest of the trailing arm back to the car first, before trying to remove that bolt. If you've got the trailing arm dangling, it sure might be tough to remove that bolt. Bolt it back up and see what happens.
Old Apr 16, 2003 | 07:22 AM
Crack Monkey's Avatar
y0! Sell that ish and build a '77!
Old Apr 16, 2003 | 09:06 AM
E-AT_me's Avatar
Default Re: compensator arm bushing is seized.. anyone experienced this before? (Crack Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">y0! Sell that ish and build a '77! </TD></TR></TABLE>
shush.
anyway, the whole trailing arm is off.. i removed it from the compensator arm.. now it's just the compensator arm on it... there's no weight on the bolt..
and sadly, yes, it is the bolt/bushing mass that spins..
Old Apr 16, 2003 | 09:23 AM
drkarrow's Avatar
same thing happened to me. I spun the rubber in the arm. I cut it out with a sawsall, and ez-out the rest of the bolt, and put in new prothane bushings. When I put the new compensator arm bushings in, they were loose to the compensator arm. So I also had to tack weld them in so they didn't spin.
Old Apr 16, 2003 | 10:26 AM
Geezer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rexman &raquo;</TD></TR><TR><TD CLASS="quote">
...and sadly, yes, it is the bolt/bushing mass that spins..</TD></TR></TABLE>
Oh, dear. You are well and truly down in the deep end of the do-do pool. Let's see. As the bolt trys to screw itself out of the captured nut, it forces the rust-welded bushing against the back of the channel that retains the inner end of the compensator arm, bending it.
You may have to try cutting the bushing on both sides of the compensator arm, as close as possible to the arm. That way, you'll have a bit of bushing and bolt you can use to finish getting the bolt unscrewed from the captured nut.
Alternatively, do you really need to change that one particular bushing?
Old Apr 16, 2003 | 04:37 PM
E-AT_me's Avatar
Default Re: compensator arm bushing is seized.. anyone experienced this before? (Geezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Geezer &raquo;</TD></TR><TR><TD CLASS="quote">
Alternatively, do you really need to change that one particular bushing? </TD></TR></TABLE>
you know.. that's what i was thinking... i might just say screw it.. but, now i've lost my rear lower bushings.. or they didn't come in the kit.. either way, i'm in another pickle.. these things are starting to taste sour...
btw, where the HECK have you been geezer?? jeese.. it's been like a year..
brewerkz
Jul 6, 2016 03:23 PM
bank2me
Aug 19, 2011 06:53 PM
jdmsupreme2132
Suspension & Brakes
Nov 6, 2009 03:19 PM
mtrivera
Sep 30, 2008 05:57 PM
danvuquoc
Suspension & Brakes
11
Jan 25, 2006 11:30 AM
