Arp head studs for d16z6 need help asap Need a pic of them installed
Old Apr 15, 2003 | 04:09 PM
ghettocrxsi's Avatar
Default Arp head studs for d16z6 need help asap Need a pic of them installed
I just got them from turboCx.. thanks btw
But they are all the same size but 1 stud is short.. I have tried every possible way and I am stuck. anyone have a pic of them installed in a d16z6? here is a pic
EDIT FORGOT PICS
ITS THE STUD IN FRONT ROW ALL THE WAY LEFT
Modified by ghettocrxsi at 7:19 PM 4/15/2003
Old Apr 15, 2003 | 04:46 PM
Default Re: Arp head studs for d16z6 need help asap Need a pic of them installed (ghettocrxsi)
ttt take a look
Old Apr 15, 2003 | 05:55 PM
BoostedED9's Avatar
the one at the top left corner should sit higher than others i belive
Old Apr 15, 2003 | 05:57 PM
TwistedHatch's Avatar
your gonna have to throw it in the gutter and go buy another....
Old Apr 15, 2003 | 06:17 PM
Default Re: Arp head studs for d16z6 need help asap Need a pic of them installed (TwistedHatch)
shut up dustin I will come key your new paint .. The one in the back does sit higher.. but when i put the shorter stud there it still you can put a nut on with like 3 threads.. is it going to be ok or is there something wrong?
Old Apr 16, 2003 | 04:55 AM
TurbodCX's Avatar
Whoa!! that stud should not sit that low in the block? they did not do that for me, thaey were to damn long when i tried them (totally different setup though)
Have you tried moving the studs around any??
Is there material missing out of the threaded holes?
Brian
Old Apr 16, 2003 | 11:09 AM
gtcali's Avatar
Default Re: Arp head studs for d16z6 need help asap Need a pic of them installed (BoostedED9)
You are correct. Top left should be higher.
Old Apr 16, 2003 | 03:09 PM
Default Re: Arp head studs for d16z6 need help asap Need a pic of them installed (gtcali)
The top left is higher...... I moved the shorter one around all over the place.. the top left sits level with all the rest when the head is on.. but the front one is teh shorter one.. I dunno why its like that I emailed rob at arp about it.. anyone else have d16z6 arp head studs?
Old Apr 16, 2003 | 05:25 PM
dynomax27's Avatar
Well i just put my arp head studs on my car and they were the same size. I'm assuming you put the wrong end in. The threading on one side is longer than the other.
Old Apr 16, 2003 | 10:19 PM
Default Re: Arp head studs for d16z6 need help asap Need a pic of them installed (dynomax27)
I will take them all out tommorow and show you guys
Cras-Delsol
Apr 17, 2010 09:28 PM
Mr.Death
Aug 9, 2006 10:09 AM
chillax
15
Jul 28, 2003 01:46 PM
