car follows the road
Old Apr 15, 2003 | 01:01 PM
ravi's Avatar
Default car follows the road
when im driving and come to a road with bumps, curves and lines in the pavement my car tends to follow the lines and my steering wheel starts to pull side to side. This happend with my 14's as well but not as much as the 17's.
My car is lowered 1.7"
how can i fix this?
thanks
Old Apr 15, 2003 | 01:08 PM
integobsession's Avatar
Default Re: car follows the road (ravi)
This is a problem that most motorists have... and I know how you can fix this...
First... You put both hands on the steering wheel...
Second... You HOLD the steering wheel.
Remember the SECOND rule to HOLD ur steering wheel.
Old Apr 15, 2003 | 01:11 PM
Aaron M's Avatar
Default Re: car follows the road (integobsession)
i notice this also.
i REALLY noticed it when i put azenis tires on
Old Apr 15, 2003 | 01:12 PM
B2FiNiTY's Avatar
Default Re: car follows the road (SilverB18C1)
lol. It could be many things. I wouldn't worry about it if your alignment is ok.
Old Apr 15, 2003 | 03:37 PM
romeo619romeo's Avatar
Default Re: car follows the road (B2FiNiTY)
i kno exactly what your talking about.. you get a certain pull and if some1 just pushed your car to the side .. its normal
Old Apr 15, 2003 | 04:10 PM
Regular Series's Avatar
Welcome to the world of low-profile tires. I actually had to spend some time getting re-acquainted with my 205/50-15s after a winter of rolling on stock size snows (which don't grab the pavement nearly as much).
Old Apr 15, 2003 | 04:30 PM
Nighthawk GS-R's Avatar
New User
Default Re: car follows the road (Risingson)
the performance tred of tires is obviously what's causing it. The treds are following the "waves" and bumps in the road. I noticed this alot more after putting on the azenis.
Old Apr 15, 2003 | 04:38 PM
acteg94's Avatar
Default Re: car follows the road (Nighthawk GS-R)
i believe the wider and the lower the profile of the tire will tend to follow the curve of the road. think about it, race cars have wider tires so it can easily curve the road with no problem. i have noticed this w my 17's but not too much w my 16's. also depends on your alignment ...
The-LS's Avatar
I think the Ecsta 712's do that too with the giant groove in the middle.
Old Apr 15, 2003 | 04:58 PM
sportyolds's Avatar
Default Re: car follows the road (Black-LS)
I noticed it too, only after I just put on yokohama Es100's.
Old Apr 15, 2003 | 05:07 PM
Ronin Integra8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integobsession &raquo;</TD></TR><TR><TD CLASS="quote">This is a problem that most motorists have... and I know how you can fix this...
Remember the SECOND rule to HOLD ur steering wheel.</TD></TR></TABLE>
i think this is my problem thanks
Old Apr 15, 2003 | 05:36 PM
slimbo's Avatar
depends alot on the wheel and tyres sizes... fat, low profile tyres tend to tramline quite badly.
i have a castor kit on my car, that made the tramline effect very noticeable...
Old Apr 15, 2003 | 06:22 PM
Brett's Avatar
Default Re: car follows the road (slimbo)
On the bmw boards we called it "bump steer." Just seems to be an effect of lowering and thin sidewalls. If I remember right I thought that a camber kit will negate the effects somewhat. Tried to look up some technical info on it but I never could find it.
Old Apr 15, 2003 | 07:04 PM
TEXN3's Avatar
Default Re: car follows the road (Brett)
its called tramlining. it happens, the grooves are in the road to help channel water in case of icing.
a camber kit will put your tires more squarely on the pavement which would give you more tread contact... and this would seem to make it worse. is this correct?
Old Apr 15, 2003 | 09:08 PM
YodiBrodi's Avatar
Default Re: car follows the road (texnteg)
lowering the car changes the suspension and steering geometry. the engineers designed the steering in a way to combat this, called bump steer and when you are applying power it is torque steer but the same principle, but that engineering was designed for a stock ride height. basically, the steering and suspension geometry is as it would be if it were in permanent compression so everything changes. that's one of those things you get when lowering a car but it's not a big deal. low profile tires with stiff sidewalls will also amplify the effect. i didn't notice any change when i installed the camber kit, at least not to the effect that it "tramlined" more.
Jaynik
Nov 11, 2010 01:13 PM
95C0upe
18
Oct 28, 2008 06:30 PM
JoKarma
Sep 20, 2005 10:56 AM
Turbo Squid
Aug 15, 2005 07:08 PM
i_krayzie_i
Apr 6, 2002 08:04 AM
