Weight savings...
Old Apr 15, 2003 | 10:52 AM
MissMyHonda's Avatar
Default Weight savings...
Has anyone actually weighed what they've taken out...I'm just wondering what the total savings of:
Rear seats
Rear Seat belts
Spare
Spare Cover
Rear Carpet
rear side panels
Rear sound deadening material
Hatch cover
is?
Old Apr 15, 2003 | 10:53 AM
E-Rok's Avatar
EPIC TUNING
Default Re: Weight savings... (JoesTypeS)
i did that and the scale at the track read 2350. but i also took out the rear seatbelt assemblies, rear speakers, rear wiper, and rear antenna.
Old Apr 15, 2003 | 10:56 AM
Default Re: Weight savings... (rewsnaeht)
2350?!?! on what car? RS? R?
Old Apr 15, 2003 | 11:01 AM
btl fed's Avatar
I'm guessing you would save 100 to 150 lbs. That is with a completely gutted rear. The seats are less than 10 lbs. The speakers are a few pounds. The spare is probably 20 to 30 lbs. The carpet is a few lbs. The antenna saves a few, as does the rear wiper. When it is all added up it could probably be up to 150 lbs. with the sound deadening/tar material also.
Old Apr 15, 2003 | 11:21 AM
E-Rok's Avatar
EPIC TUNING
Default Re: Weight savings... (btl fed)
LS...
Old Apr 15, 2003 | 11:29 AM
howd u shave almost 300lbs stock is 2643....
Old Apr 15, 2003 | 11:52 AM
Tweakmeister's Avatar
I'm going to guess maybe 100lbs...150 tops.
Old Apr 15, 2003 | 12:35 PM
TerribleOne's Avatar
Default Re: Weight savings... (Tweakmeister)
2480 on a GSR with teh back seats/sparco sprint front seats/ spare and jack removed/1/2 tank of gas
Old Apr 15, 2003 | 04:59 PM
2fstGSR's Avatar
Default Re: Weight savings... (TerribleOne)
My car weighed 2200 lbs at the track with everything removed including the passenger seat. See pic below
Old Apr 15, 2003 | 07:43 PM
TymLesxRS's Avatar
Default Re: Weight savings... (2fstGSR)
Not trying to jack this thread, but since we are talking about weight reduction, how do you remove sound deadening? what type of tools are needed? techniques? thanks i appreciate it guys.
Old Apr 15, 2003 | 07:51 PM
Project SSAP1's Avatar
from Mike K's old post
https://honda-tech.com/zerothread?id=131602
*front bumper support
*rear bumper support
*ABS system
*switched PS rack to manual Civic CX unit
*ditch OE manifold and cat for a 4-1 w/ test pipe
*remove sound deadening(GSR/LS only)
*remove rear wiper and motor
*shave antenna and remove antenna motor
*driver and pass. air bags
*SRS harnesses and SRS control module
*apexi' WS suspension (total 12lbs. lighter than stock altogether)
*aluminum flywheel(much lighter than stock)
*remove passenger side dash brace(thick *** bar behin dash)
*lightweight rotors
*leightweight wheels
*AEM (lighter than OE intake system)
*remove strut tower bar and rear upper and lower body braces, also considering sway bars.. but this was DRASTICALLY hurt the car's handling and performance
*switch out power door lock actuators for Integra RS units
*spare tire and jack(DUH)
*evap and emissions system and canister (not applicable to all. there is no emissions or inspection here, so I do it.)
*brake dust shields
*exhaust tunnel heat shield
Old Apr 16, 2003 | 10:00 AM
gigantor's Avatar
drain the oil out of the motor and tranny. that's about 50lbs right there!
Old Apr 16, 2003 | 10:10 AM
VTEC-DA's Avatar
Default Re: Weight savings... (gigantor)
If you are serious about weight, gas weighs a ******* ton. When you race, make sure you are close to empty, if weight is that important to you.
Old Apr 16, 2003 | 11:40 AM
Default Re: Weight savings... (VTEC-DA)
http://www.hogens.com/car/defa...x.php
for removing the tar. I've actually done it in warmer weather and didn't run into any problems either.
Old Apr 16, 2003 | 11:46 AM
gsrvx's Avatar
New User
In my hatch...I took the following out:
-rear seats
-spare tire/jack/tools
-cargo cover
weighed in at a total of 59lbs.
-Rod
Old May 16, 2003 | 05:50 AM
Default Re: Weight savings... (TymLesxRS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TymLesxRS &raquo;</TD></TR><TR><TD CLASS="quote">Not trying to jack this thread, but since we are talking about weight reduction, how do you remove sound deadening? what type of tools are needed? techniques? thanks i appreciate it guys. </TD></TR></TABLE>
I just took a Mallet and a screw driver, sure there are some scratches but hell, it worked...
Old May 16, 2003 | 06:40 AM
Volcom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC-DA &raquo;</TD></TR><TR><TD CLASS="quote">If you are serious about weight, gas weighs a ******* ton. When you race, make sure you are close to empty, if weight is that important to you.</TD></TR></TABLE>
Fuel weighs 6 pounds a gallon
Water weighs 8 pounds a gallon
Old May 16, 2003 | 08:04 AM
dohc-nyne's Avatar
rear ls seats weighed in at 20 lbs on my car...
Old May 16, 2003 | 08:23 AM
TeamSTEALTH GSR's Avatar
3 piece rear seats = 30lbs
seat belts+antanna+ rear speakers+bolt and every other lil thing=12lbs
spare tire=29lbs
2 side panels and rear panel= 16lbs
i didnt get a chance to weigh the sound deadening ,... just trashed it.
hatch plasic with complete windshield wiper ~12lbs
carpet + spare cover=??? never had one.
Old May 16, 2003 | 08:27 AM
P1mpSlap's Avatar
In my GSR, I never fill her up past 1/2 way anymore. She feels too slow when I do that.
I havea gutted back area with sound dampening removed.
Amazingly the sound dampening material weighs a very good amount. So I suggest everyone remove that if they have some time.
If you only fill your car up 1/2 way for about a month. Then fill her up to FULL. You'll notice a HUGE change. Then when she's on 1/8th of a tank she'll perform at her best b/c there's almost nothing in the car.
Old May 16, 2003 | 10:15 AM
Typiko512's Avatar
Default Re: (P1mpSlap)
took out those and didn't make that much of a difference. thought mayb my car would be way faster but i guess the turbo made it the same. So i had to put back most of the things including the center console and some tools i carry with me in the car just in case if $hit happens. I think the car looks and feels better with interior. if i was going to take out everything, then i would probably do it on a civic or something not an acura.
Old May 16, 2003 | 11:40 AM
Default Re: (Typiko512)
Well I took out my back seats and I think it looks ok, some of the sound material too, and I have fiberglass fender and racing seats...so I trimmed some lbs...
Also guys if you're wondering how much your car weighs ever you can goto a sand and gravel dealer (ya know in the industrial sections of cuties) they have a scale for the trucks and are usually very kind and let you use it...
Old May 16, 2003 | 01:06 PM
sergio's Avatar
I don't want to hijack the thread as well, but I have a question. I am also thinking of taking things out of my car for weight reduction (when I pay off my car in a year and some months), like the rear seats and such. I plan on driving my car for a long time so would it be okay to throw away the seats and everything I take out? I wouldn't have anywhere to keep them. So if I decide to sell the car at some point, would I just sell it without the things I took out or would people not be interested in the car?
Old May 16, 2003 | 01:16 PM
Calavera's Avatar
Default Re: (sergio)
If you take out seats and such, don't throw it away. you can make a lil money by selling it. Later if you decide to sell and nobody bites, you can buy stock seats again.
Old May 16, 2003 | 01:26 PM
allmotorls95's Avatar
Default Re: (Calavera)
the best way to take off the sound deadining tar is to use dry ice, mallet, and a hammer...it worked like a charm for me
