help building an na d16a6
Old Apr 15, 2003 | 10:45 AM
blackrex91's Avatar
Default help building an na d16a6
I have a 91 crx dx and i have a extra d16a6 i want to build all motor but i still want to be able to run pump gas. I am looking for suggestions examples anything. i also want to know if i should use anything i have already. i have: crane cam(idle-6800), aem adjustable cam gear, dc sports header, cat-back 2 1/4" exhaust, gutted cat., c.a.i., full msd ignition, d16z6 manifold with the multi-port swap done, and a 1989 integra computer. i would appreciate any help
Old Apr 15, 2003 | 11:15 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: help building an na d16a6 (blackrex91)
88-89 integra D16A1 pistons
shot peen/polish rods. lighten flywheel, shave the pulley, work on the head (clean the ports, metal head gasket.
and oh yeah
do a search here, LOTS of info floating around
stan
Old Apr 15, 2003 | 11:59 AM
slowman's Avatar
I took way too long
Default Re: help building an na d16a6 (90crxsi)
ive got quite a few mods on my d16a6. one of them being a crane cam stage 2 with skunk2 cam gear. it really has made a good difference in power. haven't gotten it over to the drag strip yet but you can see/hear the car in the link in my signature. i love the a6 and my goal is 14s N/A. any other questions just ask.
my setup:
i/h/e, cat replaced with resonator, ebay fart pipe, 2.25inch piping, crane cams cam stage 2, skunk2 cam gear set at 3* advanced.
Old Apr 15, 2003 | 06:46 PM
sporkcrx's Avatar
Default Re: help building an na d16a6 (slowmanEF)
they seem to perform really well when you open up the ports in the head and let them breathe
Old Apr 15, 2003 | 07:28 PM
G2turbo_terror's Avatar
Default Re: help building an na d16a6 (sporkcrx)
If your gonna open it up do what 90crxsi said. Otherwise you can use a y8 head gasket to bring you c/r up to 10.3 A 58mm integra TB will bolt to your manifold. And some head work will work wonders, but make sure the shop that does it takes into consideration the mods you have or plan to do.
Old Apr 16, 2003 | 06:28 AM
blackrex91's Avatar
Default Re: help building an na d16a6 (G2turbo_terror)
what year integra throttle body fits? I did a search and it said a 90 should fit and it looks like it will the only problem is the iac valve, i think it is, is on the tb. the integra tb has the iac on the intake.
Old Apr 16, 2003 | 07:13 AM
if you use a Y8 or Z6 intake mani, pretty much ANY TB from B series will fit. or H. i heard S2K TB fits also.
stan
Old Apr 16, 2003 | 07:20 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackrex91 &raquo;</TD></TR><TR><TD CLASS="quote">what year integra throttle body fits? I did a search and it said a 90 should fit and it looks like it will the only problem is the iac valve, i think it is, is on the tb. the integra tb has the iac on the intake. </TD></TR></TABLE>
if your staying NA use a 90-91 teg TB on the Y8 manifold...58mm. its set up pretty much the same as the a6 TB...MAP on firewall, dashpot, and uses charcoal canister.
the eacv/iacv is on the back of the manifold on the manual tranny Y8 manifold...on the auto its on the TB. use the manual tranny Y8 manifold.
heres pics of what im talking about:
https://honda-tech.com/zerothread?id=461235
joeystritch
25
Jul 21, 2011 11:36 AM
sxysweed
Oct 11, 2010 12:32 PM
minime ef
Nov 4, 2004 07:52 AM
youngwon22
22
Jun 29, 2004 07:42 PM
fastfu
Jun 17, 2004 09:08 AM
