Suggestions before I start using my Harbor Freight Aluminum Jack?
Do I need to do anything besides bleed it? Just want to make sure before I start using it. Sale is still on at Harbor Freight. $169.99 for the jack at the store. Sale ends 4/21 - just for your info.
Mike
Mike
careful with the screw that locks the handle into the base. It strips very easily since the base is aluminum. 2 times I have lent the jack out it has come back stripped
Don't have your face over the bleeder screw when you're bleeding it. It sprays a pretty good stream of oil. Cover it with a rag and use hydrolic jack oil.
$.02
$.02
for those who have blead it:is the pump action nice and easy or is it incredibally hard? a friend picked one up and we just started using it w/o bleeding and the pump action is very hard.
-spenc
-spenc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOLOef »</TD></TR><TR><TD CLASS="quote">for those who have blead it:is the pump action nice and easy or is it incredibally hard? a friend picked one up and we just started using it w/o bleeding and the pump action is very hard.
-spenc</TD></TR></TABLE>
mine is hard. but then again I think I got a peice of crap, because it is inconsitent, squeaks and doesnt hold its height
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elgorey »</TD></TR><TR><TD CLASS="quote">
mine is hard. but then again I think I got a peice of crap, because it is inconsitent, squeaks and doesnt hold its height</TD></TR></TABLE>
It's harbor freight, what do you expect? I hate buying stuff from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOLOef »</TD></TR><TR><TD CLASS="quote">for those who have blead it:is the pump action nice and easy or is it incredibally hard? </TD></TR></TABLE>
With a car on it, you have to use some force.
Hrm. I must have purchased the wrong model. This one takes forever to get up to full height. My friend's gets to full height in 7 pumps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustChou »</TD></TR><TR><TD CLASS="quote">
It's harbor freight, what do you expect? I hate buying stuff from there.</TD></TR></TABLE>
i ordered a breaker bar set (how ghetto could those actually be right?) and one of the two is missing the ball in the drive that locks the socket into place
after that thread about the harbor freight jackstands giving out under the weight of a crx, i have been leary of buying their stuff. when we use the jack, we always use jack stands. or stuff a wheel under the tires that are in the air.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRacer »</TD></TR><TR><TD CLASS="quote">Hrm. I must have purchased the wrong model. This one takes forever to get up to full height. My friend's gets to full height in 7 pumps.</TD></TR></TABLE>
Keep bleeding. Mine went from about 15 out of the box, to about 7-8 after bleeding and slow, full pumps. Keep in mind what you'll use the jack for. It's a track tool for tire changes mainly and it only takes 2 pumps to get the tires off the ground - even if it's 8 to the top.
Humm I got my trailer from them and I'm super happy with it. And when I move to Orlando I'll shop there more often.
Well I bled the system and it pumps up in 8. Do you guys leave the bleeder valve in or put the other solid piece in?
Hmm. Mine worked fine out of the box, and ever since. I'm not surprised that it takes a bit more effort than a usual 20+ pump floor jack. Ever notice that the NASCAR guys with their custom jacks usually have the heaviest guy as jackman, and he throws all his weight on the handle? You don't get something for nothing, and less pumps = more effort.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martini »</TD></TR><TR><TD CLASS="quote">here's my suggestion:
paint it mad skillz yellow.</TD></TR></TABLE>
Hey now, my pimpy yellow Performance Tool jack has a 5" min height and a 23" max height but it weighs a ton. Cost about... 1/3 of that harbor freight one, though.
dc r-spec
Dec 25, 2005 03:06 PM
