built h22/h23 guys with boost....
Old Apr 15, 2003 | 07:49 AM
BoostedH23a1's Avatar
Default built h22/h23 guys with boost....
well im gonna build my h23 and i was gonna have GE sleeve it.. i plan on running about 17psi daily and maybe more at the track.. my question is how big of bore can/should i go.. .02? or bigger? also what about oil pumps.. i hear some bad things about prodrive...
Old Apr 15, 2003 | 08:24 AM
PrecisionH23a's Avatar
Default Re: built h22/h23 guys with boost.... (BoostedH23a1)
i still use my stock oil pump. As far as bore size, most pistons for our applications are 20 over. Im currently 40 over at 88mm (stock is 47mm). The darton sleeves i use can safely go to an 89mm. I would just use a regular 20 over since those are shelf pistons and not customs.
Old Apr 15, 2003 | 08:33 AM
UberTeg's Avatar
Default Re: built h22/h23 guys with boost.... (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">Im currently 40 over at 88mm (stock is 47mm)</TD></TR></TABLE>
wow, vince is getting good if he can overbore 41mm
Old Apr 15, 2003 | 08:38 AM
DLB1994's Avatar
Default Re: built h22/h23 guys with boost.... (UberTeg)
yeh ill get 87.5mm or 88mm to be safe. What comp you want to go with
Old Apr 15, 2003 | 08:45 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote"> Im currently 40 over at 88mm (stock is 47mm).</TD></TR></TABLE>
Man, is there any cylinder material left?! LOL!
I would stick with 88 at the most. 89 is getting really thin...and you'll need as much stability you can get when boosting. Trust me, 15psi+ on an H23 will make plenty of torque...you probably won't gain any discplacement advantage by going to an 89mm bore. This is a daily driven car, right? Keep it simple and reliable.
Old Apr 15, 2003 | 09:15 AM
Im sorry to mention im using Darton sleeves that Benson's supplied me with for my 88mm h23a bore.
Old Apr 16, 2003 | 06:40 AM
im thinkin 9:1... do they make like a 9:2:1 or something.. that way less boost and same power...
Old Apr 16, 2003 | 07:17 AM
DLB1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedH23a1 &raquo;</TD></TR><TR><TD CLASS="quote">im thinkin 9:1... do they make like a 9:2:1 or something.. that way less boost and same power...</TD></TR></TABLE>
hows that if your dropping it from stock
stock is 9.8:1
thats why am running 10.2:1comp see the tq am making at that low psi
Old Apr 16, 2003 | 07:28 AM
symba's Avatar
Default Re: built h22/h23 guys with boost.... (DLB1994)
damn, DLB1994, that is some tq you got there. What is your fuel management like? Do you get paranoid at all about detonation at that c/r with 12psi daily?
Old Apr 16, 2003 | 07:59 AM
DLB1994's Avatar
Default Re: built h22/h23 guys with boost.... (symba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by symba &raquo;</TD></TR><TR><TD CLASS="quote">damn, DLB1994, that is some tq you got there. What is your fuel management like? Do you get paranoid at all about detonation at that c/r with 12psi daily?</TD></TR></TABLE>
running hondata with 756cc injectors and 3bar map 255intank pump
naw i have not got any detonation yet
Old Apr 16, 2003 | 08:10 AM
im comparing that to 9:1 pistons... also should i get dome or flats or what
Old Apr 16, 2003 | 08:24 AM
symba's Avatar
I would go with flats to prevent hot spots...but that's just my .02
Old Apr 16, 2003 | 11:02 AM
ludesleep's Avatar
i have a sleeved h23 87mm block for sale 400 bux please someone take it off my hands!
Old Apr 17, 2003 | 06:13 PM
93turbolude's Avatar
Default Re: built h22/h23 guys with boost.... (ludesleep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesleep &raquo;</TD></TR><TR><TD CLASS="quote">i have a sleeved h23 87mm block for sale 400 bux please someone take it off my hands! </TD></TR></TABLE>
what kind of sleeves, where are u located..... and what condition is the block in?? email me...... VERY VERY INTERESTED
Old Apr 21, 2003 | 01:33 PM
ludesleep's Avatar
Default Re: built h22/h23 guys with boost.... (93turbolude)
i have pics of the block now if anyone wants to see it
Old Apr 22, 2003 | 04:47 PM
ludesleep's Avatar
thanks KTeller8
here ya go
Modified by ludesleep at 5:57 AM 4/23/2003
Old Apr 22, 2003 | 08:27 PM
KTeller8's Avatar
JDM4DRACCORD
Jan 3, 2007 09:04 AM
XLR8_HFX
Oct 18, 2006 04:08 PM
1RMDave
Mar 24, 2006 07:14 PM
H22aBB2
Feb 6, 2006 01:47 PM
