Let's see your VAFC mount pics!!
this dude dave i know kinda cut a whole right above his glove box and it looked really good...it was on a 92-95 hatch though.
steve
steve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp »</TD></TR><TR><TD CLASS="quote">Nice install, but isn't it hard to see the display when it's way down there?</TD></TR></TABLE>
Actually, I can see it just fine: 1) I only really need to "see" it while tuning. 2)I have S2k seats/rails, so I sit about 2 inches lower than stock = easier to see since I'm lower. Thanks for all the
! Anyone else have pics?...Let's see 'em!
not sure if its original but its definately nice, however, where do you put your change? did you just take the change drawer out and thats it? then just mount it in with double sided tape everywhere? i have one that isnt installed yet and im looking a for a place to mount as well. insdie the glove box is good way to keep it from theives
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline07 »</TD></TR><TR><TD CLASS="quote">your mounting place is tight!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 »</TD></TR><TR><TD CLASS="quote">Not a VAFC but close.
Stealth!
</TD></TR></TABLE>Stealth!
The "change drawer" is actually the ASHTRAY . I keep my change in the CHANGE DRAWER to the left of the steering column. Since I don't smoke ( and I don't keep anything in the ashtray, removing it was no biggie for me. It is not a direct replacement for the ashtray....the VAFC is slightly larger than the opening. Some cutting is required. Once you remove the material necessary to fit the VAFC, the ashtray can no longer be reinstalled.
I removed the cupholder so I could gain acces to the underside of the mounting surface where I bolted the supplied Apexi bracket. I then mounted the VAFC to the bracket with the supplied double-sided tape. The upper console (frame that holds the radio basket) supports the top of the VAFC also. Basically, it is rock-solid and flush!
thats cool. does the other end show much through the back of the visor?
very nice
</TD></TR></TABLE>thats cool. does the other end show much through the back of the visor?
very nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cccya »</TD></TR><TR><TD CLASS="quote">
very nice
Not at all its totally flat. Little cutting, some epoxy, and walla you got a sleeper install that wont show off your $500 boost controller.
very nice
</TD></TR></TABLE>Not at all its totally flat. Little cutting, some epoxy, and walla you got a sleeper install that wont show off your $500 boost controller.
