MPFI Wiring?
Old Apr 15, 2003 | 05:00 AM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default MPFI Wiring?
I did numerous searches, And yeilded nothing. Ok, There are 3 wires coming from the injector harness, Going to the passenger side... What do they go to, The wires have been cut so I have no clue. The colors are Blue/Yellow stripe, Teal or a blueish gray, And what looks to be pinkish or peach/Black stripe. Any help would be much appreciated...
Old Apr 15, 2003 | 05:09 AM
h8tred's Avatar
Default Re: MPFI Wiring? (h8tred)
The blueish maybe faded green one and peach/black stripe go to the intake temp sensor... The blue/yellow stripe goes to the dizzy right? What do they connect to is the new question at hand...
Old Apr 15, 2003 | 06:13 AM
jlicrx's Avatar
i believe that what you are seeing is the blue/yellow which is EACV (Si only), green which is the purge cut-off solenoid valve (Si only), and brown/black which is ground - i assume you have Si harness - what engine and car is this in?
Old Apr 15, 2003 | 06:37 AM
h8tred's Avatar
Default Re: MPFI Wiring? (jlicrx)
I'm putting an 89 crx si engine into a 91 civic dx. I assume I'm to take the (TA) sensor plug completly off the si injector harness and use the existing one on my dx engine harness. The only wiring I have for the si is the injector harness.
Old Apr 15, 2003 | 06:52 AM
h8tred's Avatar
But where does the Blue/yellow stripe one go?
Old Apr 15, 2003 | 07:03 AM
zcivicz's Avatar
can you tell which injector the blue/yellow wire is coming from ?
Old Apr 15, 2003 | 07:04 AM
h8tred's Avatar
jlicrx, Thanks for the reply. Everyone else, YOU SUCK! haha... I'll figure it out on my own, That shall make me the better man. Mods delete this worthless post...
Old Apr 15, 2003 | 07:27 AM
h8tred's Avatar
It's not coming from an injector at all, Rather the square 6 pin plug on the drivers side, Parallel to the injector resistor plug. It runs the length of the injector harness and is cut close to the distributor.
Old Apr 15, 2003 | 01:18 PM
h8tred's Avatar
Default Re: (h8tred)
Old Apr 16, 2003 | 05:14 AM
h8tred's Avatar
Up
Old Apr 16, 2003 | 08:06 AM
zcivicz's Avatar
hmmm...i would have to look at my own mpfi swap when i get my car back...i'll let you know if you haven't already figured it out.....or someone else....
Old Apr 16, 2003 | 08:13 AM
h8tred's Avatar
Default Re: (zcivicz)
Yes, Please... I would appreciate that very much. I have 3 more days to get it in and running or I'll be paying a fine that's half of what I paid for the car
Old Apr 16, 2003 | 08:36 AM
uneek4dr's Avatar
ok imma take a guess......
when i pulled the harness from an HF it had that wire.... the only blue/yellow wire that comes from that harness would be the one on the SI dizzy plug......could that be the one you are looking for?
Old Apr 16, 2003 | 09:05 AM
h8tred's Avatar
Default Re: (uneek4dr)
I guess, So I dont need it then, I'm just going to make a 2 pin plug at the dizzy for the ca sensor. I guess that on the si It had it going over to the drivers side...
Old Apr 16, 2003 | 09:09 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Old Apr 16, 2003 | 12:42 PM
h8tred's Avatar
Default Re: (88DXCRX)
I've seen that before, It's good and all, But it tells me nothing about the existing si injector harness... Thank you though.
Old Apr 23, 2003 | 01:01 PM
Simple's Avatar
would this also work if swapping a newer (92-95) civic motor in? or a D16z6, plus Vtec wires?
Old Apr 23, 2003 | 04:33 PM
4drEF's Avatar
Keyboard Humorist
I think you are talking about that little 2 wire connector on the Si harness that is NOT on the DX harness. It's that little plug that's found between the injector plugs and the injector resistor box plug. That one?
Old Apr 26, 2003 | 06:50 PM
h8tred's Avatar
Default Re: (4drEF)
I got another question, If your looking at the back of the intake mani, To the left of the eacv. There is a sensor with an ovalish plug, What is it? I've went thru my crx workshop manual, But I can't find anything about it in there... Anyone know? Thanks in advance
Old Apr 26, 2003 | 11:09 PM
matt j's Avatar
dont know if this helps but here you go
Old Apr 26, 2003 | 11:23 PM
h8tred's Avatar
Default Re: (mattED6)
It's whatever this hose goes to. It don't say anything about it in any of the dpfi to mpfi write ups I have seen.
Old Apr 27, 2003 | 06:41 AM
zcivicz's Avatar
i'm pretty sure you're talking about the fast idle solenoid valve ?! you don't plug that into anything and it doesn't throw any codes either. when all is done you will have one plug left hanging from the dx harness. you don't need it unless you live in a really cold place during winter like i do
Old Apr 27, 2003 | 07:53 AM
h8tred's Avatar
It has been known to get pretty cold around here. Is that one remaining plug for the fast idle joint? If so, I can just change the ovelish plug for the one that fits the dx harness... Thanks again
Old Apr 27, 2003 | 01:56 PM
h8tred's Avatar
I'll assume that's right...
thatHEMIguy
Mar 4, 2010 08:57 AM
(760)doogie
Mar 21, 2008 12:55 PM
hatchinprogress
Jan 15, 2006 07:42 AM
e jay one
17
Sep 9, 2005 05:15 PM
gocivicgo
May 16, 2003 01:45 PM
