Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Suspension settings?
Old Apr 15, 2003 | 03:35 AM
revvhappy's Avatar
Default Suspension settings?
96 GSR with KYB/AGX adjustables and Eibach Pro-kit, ST Anti-sway in the rear. Car tends to oversteer slightly and I was wondering if changing the shock settings might help... i.e. Stiffer in front, softer in the rear or vice versa??? I've been setting all 4 corners the same for aggressive driving and the back just feels twitchy and steps out first.
Old Apr 15, 2003 | 03:54 AM
ChrisShen's Avatar
Default Re: Suspension settings? (revvhappy)
this is weird. your setup shouldn't cause you oversteer so much. it's a complicated thing to resolve here, but a couple thoughts. are your rear tires ok? rear alignment ok? is the rear bar binding?
I'd say it's related to something in the rear of the car. Soften the rear of the car up as much as possible and see if you still have the same problems. The Pro-kits are very rear soft as it is. And the ST rear bar will create more oversteer, but not that much. Are your problems occuring at very high speeds only?
Weird.....
Chris
Old Apr 15, 2003 | 04:48 AM
.RJ's Avatar
.RJ
If it oversteers, be smoother with your steering inputs and get on the gas very early.
Old Apr 15, 2003 | 08:17 AM
revvhappy's Avatar
I have new Ecsta 712s (215/40 17... had to get big rims to fit the Wilwood brakes). I was driving at Deal's Gap in TN this past weekend and the road doesn't allow more than 60mph. The problem is definitely worse at higher speeds, but I don't often go through corners above 80mph. I'll try setting the rear softer than the front and see what happens. I'll also try to smooth out my driving style and trust that FWD allows earlier throttle application. I'm still getting used to this after years of RWD cars. Thanks for the advice.
Old Apr 15, 2003 | 08:51 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revvhappy &raquo;</TD></TR><TR><TD CLASS="quote">Itrust that FWD allows earlier throttle application</TD></TR></TABLE>
On a rear stiff setup its almost a requirement to apply throttle on turn in and feed it in as you apex the turn.
Old Apr 15, 2003 | 08:52 AM
metalworker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revvhappy &raquo;</TD></TR><TR><TD CLASS="quote">I have new Ecsta 712s (215/40 17... had to get big rims to fit the Wilwood brakes). I was driving at Deal's Gap in TN this past weekend and the road doesn't allow more than 60mph. The problem is definitely worse at higher speeds, but I don't often go through corners above 80mph. I'll try setting the rear softer than the front and see what happens. I'll also try to smooth out my driving style and trust that FWD allows earlier throttle application. I'm still getting used to this after years of RWD cars. Thanks for the advice.</TD></TR></TABLE>
Boy, your not from around here are you? We don't like talk like that in these parts. I'm sure RJ is gettin his little bottle of green Loctite as I type this.
Old Apr 15, 2003 | 09:25 AM
revvhappy's Avatar
Default Re: Suspension settings? (metalworker)
If the original post doesn't get me locked, this certainly will... I'm just a displaced yankee trying to fit in below the Mason/Dixon
street_ride14
Oct 1, 2014 05:16 PM
DA9 Integra
25
Jun 22, 2006 02:57 PM
Tweakmeister
26
Jan 4, 2005 01:17 PM
SPiFF
Feb 7, 2004 04:49 PM
trhoppe
20
Aug 12, 2003 09:19 AM
