Spoon / ITR Cams
Hi,
i have a set of Spoon cams, but the exhaust cam has a damaged lobe
Therefore my question: Can i use the ITR intake cam as exhaust cam with the Spoon intake cam ?
The cam specs:
Spoon Sports
11.53 mm, duration - 256 @ 1mm (Intake)
11.13 mm, duration - 245 @ 1mm (Exhaust)
Integra Type R
11.5 mm, duration - 240 @ 1mm (Intake)
10.5 mm, duration - 235 @ 1mm (Exhaust)
Is 11.5 mm lift too much for the stock valve springs ?
Thanks, Andre
The cam specs:
Spoon Sports
Integra Type R
Thanks, Andre
Better would the other way round
EDIT:
Sorry, got you wrong...
I` d try spoon intake and itr exhaust cam.
Stay within stock powerband and you`ll be fine.
Modified by ITR1858 at 1:28 PM 4/15/2003
EDIT:
