Help request: About my weird fuel indicator (needle)
Old Apr 14, 2003 | 10:48 PM
bensonwrx's Avatar
Default Help request: About my weird fuel indicator (needle)
Ever since I bought my 93 Civic CX (for 10 months), I have noticed that the needle for fuel indication is acting funny.
During acceleration (2.5k or above), the needle would drop at least 1/8 of the entire range. If I accelerate and do a right turn, the needle will drop like 1/4; so from 3/4 of the tank to 1/2 indication. Now after the car is settled and cuirsing, the needle would go back up 1/8 @ max. If I added a left turn to this, then I will get like 1/4 of the tank back! Finally, if I go downhill easy the needle would rise a little.
I know the amount of fuel doesn't give and go like what the needle indicated, so I wonder if it is a particular sensor malfunctioning?
I have also heard that all Civic has this weakness, so I should NEVER look at that anyway. But I just found that a bit annoying, and very weird. I understand that the needle shall drop b/c the car is using up fuel, but it just shouldn't rise (and even like 1/4 of the tank) that dramatically.
Any idea and help on this? TIA!!!
Old Apr 14, 2003 | 10:56 PM
eh3 93's Avatar
Default Re: Help request: About my weird fuel indicator (bensonwrx)
Its because the fuel level sensor sits at the front of the tank so if you are going downhill all the fuel shifts to the front causing the sensor to read more fuel.
Old Apr 15, 2003 | 12:03 AM
bensonwrx's Avatar
Default Re: Help request: About my weird fuel indicator (eh3 93)
So are all Civic have this common problem, or just mine?
Is there a cure for this?
Thanks
Old Apr 15, 2003 | 09:55 AM
eh3 93's Avatar
It's not really a big deal so you have nothing to worry about. They all do it including mine.
Old Aug 2, 2003 | 10:32 PM
bensonwrx's Avatar
Okay, I am bringing this topic back up...for the reason that the indication is getting worst (or at least that's what I think).
The other day I was going home after school and the civic stop on a red light to do a left turn. It stopped slowly and it's a bit inclined, so the fuel needle drop about 1/8 of the tank.
Then, when car started to turn left, I noticed the needle droped but had to keep my eyes on the road. After the 90 degrees turn was done, I noticed the needle dropped from a bit less than half tank to almost empty!
Soon I had to make a right turn, and afterward the needle went back to a bit over 1/4 tank...
I mean this is just driving me crazy...I can use the odo well, but my gf is asking me if there's a fix to this problem? Since I do not know of an answer, I am hoping someone who can give me some idea.
Thanks in advance for any info!
Old Aug 3, 2003 | 08:17 AM
bensonwrx's Avatar
bump! Hoping for some answers...
Old Aug 4, 2003 | 12:02 PM
bensonwrx's Avatar
bump again
Old Aug 4, 2003 | 12:47 PM
Marauder's Avatar
I have no idea on a fix....mines really screwy. I was at a stop with just over half a tank and the needle dropped all the way to E and stayed there. Later, after I got moving it slowly came up and then dumped back down to E.
Personally, I don't give a **** since I know how much fuel I use and how far I can drive. Its annoying, but as long as you know your fuel ecconomy range, just use the trip meter to judge when you need to refuel.
Old Aug 4, 2003 | 02:06 PM
bensonwrx's Avatar
Default Re: Help request: About my weird fuel indicator (Marauder)
Ah, so it's not just mine that works like this...wish someone had done a fix to this, like maybe getting the fuel sensor thing from, um, integra?
She's a very nice car, just kind of odd on that particular design.
Old Aug 14, 2003 | 06:59 PM
bensonwrx's Avatar
bump for options/idea besides using the odo? TIA
Old Aug 22, 2003 | 08:58 AM
Marauder's Avatar
Do you happen to have any aftermarket ignition in the car?
I just changed some stuff on my car and testing out something that may have fixed my fuel gauge.
Old Aug 22, 2003 | 09:24 AM
Pat McGroin's Avatar
I have the same problem in my 92 CX. But it all goes back to normal after a few minutes of cruising in fifth. I notice it going down when i am accelerating 1-4 gears.
Old Aug 22, 2003 | 09:53 AM
Marauder's Avatar
Default Re: Help request: About my weird fuel indicator (Pat McGroin)
That's normal....my problem is much more severe. Just sitting still, with the needle just about 1/2, the needle would drop to E and stay there. Then slowly creep back up to where it was. The car didn't move the whole time, just idling.
Similar things would happen just cruising in 5th gear on the freeway.
mudpuppy4life
Jan 31, 2015 07:34 AM
Achenar
Mar 11, 2007 11:46 AM
EF8 D-UNIT
Mar 16, 2006 04:49 PM
CRneXt
Apr 15, 2003 08:44 PM
F120man
10
Oct 1, 2002 10:12 PM
