Help please...suspension experts needed.
I am ready to buy the Tein RA setup. I know I have to switch the rear lower control arms to 88 CRX (or ITR) units. Where does that leave me for rear sway bar options? I was looking into progress suspension sway bars, but they have a side note that says you must change the rear LCA's to 92-95 civic LCA's, if you have an 88 CRX!! Also I was looking at the sperical bearings from progress, they also have a side note to change to 92-95 civic LCA's if you have an 88 CRX!
I need to know what rear sway bar will be compatible with the Tein RA suspension on a 90 HB?
Also: Will I need a front and rear camber kits with the Tein RA suspension? It has the upper pillow mounts inculded, so will that take care of all my camber adjustment issues?
Thanks homies!!
Thanks homies!!
You will def. need the 88/ITR rear LCA to run the RA's and ST makes a kit to fit their sway and still on 88/ITR type LCA's. I tried this with my HA's and it rubbed the struts so I sold the sway because I didnt wnat to be that ghetto on my car. Also if you wanted to you can use a ITR rear sway with the RA's I have pics of how to set it up so you dont get subframe tear out or anything like that. If you need more help. Just post up or IM me.
atc5
21
Nov 29, 2005 10:16 PM
