grinding gear
when i go into 3rd gear it always grinds a little. it only seams to do it when the engine is hot. so what is the problom? all the other gears are fine. but every once in a while i have a little trouble w/ 2nd gear too?
from what you described it sounds like the 2nd+3rd gear syncros are going bad. I have the same problem in my 91STD. from what I have heard 3rd is almost always the first to go in any manual. good luck.
H2nr
Jul 12, 2004 08:52 PM
