Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Spring Free Length & Int. Diameter....any effect on handling?
Old Apr 14, 2003 | 05:52 PM
RacerBowie's Avatar
Default Spring Free Length & Int. Diameter....any effect on handling?
Just what it says.
Assuming no coil binding or ride-height issues, would there be any differences in handling between say, a 5 inch, 2.25 diameter, 500lb spring, and a 6 inch, 2.5 diameter, 500 lb spring.
I don't think there would be, but i tend to oversimplify, and wanted to bounce it off the folks here.
Racing content: Setup thoughts for the ITA car.
Old Apr 14, 2003 | 06:00 PM
Tyson's Avatar
Default Re: Spring Free Length & Int. Diameter....any effect on handling? (RacerBowie)
coil binding IS the issue. it otherwise functions as a simple spring and hopefully at the rated spring rate.
Old Apr 14, 2003 | 06:01 PM
Catch 22's Avatar
Less weight.
Less tendency to bind.
Thats all I can think of.
PS - You coming to the double at Roeblingbling?
Old Apr 14, 2003 | 07:33 PM
CRX Lee's Avatar
All else being equal there should be no difference but the longer spring is less likely to coil binda dn less likely to fall out of it's spring seats when unladed. Also 2.5s tend to be cheaper and more plentiful plus lighter.
You can go with the 2.25s if you want but I can;' think of a good reason on that car unless you already have them. Usually the 2.25s are for smaller cars that have very restrictive room in their uprights and need the smaller OD for packaging purposes. Most comon on small formula cars. On cars like Hondas whewre there is plenty of room, the 2.5 just has more options.
Understeer
71
Dec 19, 2007 08:57 AM
riceforlife
Suspension & Brakes
Dec 18, 2007 05:10 AM
EJ8 Kenobi
Suspension & Brakes
12
Jun 1, 2007 06:05 AM
Jhonny Ricer
Suspension & Brakes
Mar 29, 2007 03:30 AM
VeilSide_Mas
Suspension & Brakes
Feb 4, 2006 10:08 AM
