jdm ITR CAT gasket ring???
Old Apr 14, 2003 | 05:36 PM
hatchboy93
Guest
Posts: n/a
Default jdm ITR CAT gasket ring???
i need the gasket ring that goes between downpipe and CAT and i have the 96 jdm ITR CAT. no one seems to have it and i was told i have to order it from japan... is this right?? does anyone here know where i can get one the one i have is leaking bad because its broke in half and nasty.... any help guys???
Old Apr 14, 2003 | 05:37 PM
poison's Avatar
have you checked with the local acrura dealership for a US ITR gasket ring?
Old Apr 14, 2003 | 05:41 PM
hatchboy93
Guest
Posts: n/a
Default Re: (poison)
no i failed to do that. i just checked with every sinlge muffler shop here. i didnt check acura because i thought that the jdm ITR downpipe and CAT were larger in diameter than the usdm version. is that tru or am i wrong???? do u think the usdm ITR CAT gsaket ring would work??? does anyone know this?
hatchboy93
Guest
Posts: n/a
Default Re: (hatchboy93)
oh the reason i chedked wiuth muffler shops was because i thought they would have larger fdiameter gaskets for u know like v8's and other cars u know
Old Apr 14, 2003 | 05:46 PM
EGsixer's Avatar
is it 2 1/2" outlet? if so u would need to order the one for a acura legend. i forget witch year just ask. but i know the legend gasket is also 2 1/2" if thats what your lookin for.
Old Apr 14, 2003 | 05:47 PM
hatchboy93
Guest
Posts: n/a
Default Re: (EGsixer)
yea its 2 1/2 in out let i do beleive its very large.....
Old Apr 14, 2003 | 05:48 PM
poison's Avatar
I believe the inlet of the jdm ITR cat is 2.35"
This is due to the 4-1 header. any ring of that size will fit.
it's not 2.5"
Old Apr 14, 2003 | 05:50 PM
hatchboy93
Guest
Posts: n/a
no i dont have the 4-1 header that was 98 i beleive.... mine is a 96 jdm ITR header and cat on a 96 jdm ITR b18c.... all i now is the inlet is pretty large and teh gsr one is definately too small for it i am confused as to what to get. i dont want to go around buying all soirts of gaskets from dealerships and they not working and i cant take them back u know
Old Apr 14, 2003 | 06:02 PM
wickedEFguy's Avatar
ok poison is right the JDM 4-1 Header is a 2.35 collector but it flares out at the end to a 2.5" collector that's why some ppl think it's a 2.5" when it sorta kinda isn't get what I'm saying?
As far as the gasket check out a USDM ITR and go to a honda dealership, you should be able to get it from any 2.5" colector
Old Apr 14, 2003 | 06:03 PM
poison's Avatar
Yea, measure the gasket ring area, I am almost positive it's the 2.35" inlet. And any ring that will go in there will work.
Old Apr 14, 2003 | 06:22 PM
hatchboy93
Guest
Posts: n/a
ok i will definately try that out thanx guys for the input.....
Old Apr 14, 2003 | 07:05 PM
xchosun1x's Avatar
2.5 inch collector is also on the s2000 and you can get a 2.5 inch donut gasket from honda or aftermarket performance shop
i got one..and it was like 20 bucks
Old Apr 14, 2003 | 07:17 PM
hatchboy93
Guest
Posts: n/a
Default Re: (xchosun1x)
xchosun1x u have a jdm ITR header with CAT ???? is that the donut that u used for sure?
Old Apr 14, 2003 | 10:24 PM
built562's Avatar
go to autozone and just tell them you want to match up a gasket because its a custom setup and they will bring out the box of gaskets and just find one that fits.
hatchboy93
Apr 23, 2003 07:15 AM
REVolution
Aug 29, 2002 07:41 AM
