oil pressure sending unit
Old Apr 14, 2003 | 01:53 PM
b16 matt's Avatar
Default oil pressure sending unit
Can you use the stock sending unit on an autometer oil psi gauge?
Old Apr 14, 2003 | 01:55 PM
VTEC-DA's Avatar
Default Re: oil pressure sending unit (b16matt)
If you use a T, then yes you can. I am pretty sure that the Autometer uses the hole that the stock sender is in, so you will need a T inorder to use both at the same time.
Old Apr 14, 2003 | 01:59 PM
b16 matt's Avatar
Default Re: oil pressure sending unit (VTEC-DA)
I mean can you actually use the stock unit on the autometer?
Old Apr 14, 2003 | 05:58 PM
VTEC-DA's Avatar
I wouldnt see why not. I dont have one personally, but I dont think Autometer would design it so you didnt use the stock unit. Best bet is to try it out and see what happens. Good luck.
departed
Jun 3, 2006 12:19 PM
88fgfd
16
Apr 1, 2004 08:05 AM
TodaSi
31
Mar 12, 2004 03:37 AM
Mugen Dom
Jul 1, 2002 07:24 AM
Another B16
Aug 28, 2001 09:32 PM
