Ignition timing w/Mugen ECU, 4-1, test pipe...?
Old Jun 26, 2001 | 03:59 AM
ZygSpeed's Avatar
Default Ignition timing w/Mugen ECU, 4-1, test pipe...?
Presently set at 17.5, thinking I might be able to back it down to around the "stock" 15.
FPR set to about 52 at the moment, warmed up idle seems a little high at around 1100 (will run w/AC though).
Just for reference I looked up Andrew's dyno plot which was for a similar set up.
https://honda-tech.com/zerothread?id=29940 https://honda-tech.com/zerothread?id=29936
Smelled just a little in the parking garage this morning, but not grossly rich or anything.
Here's the kicker, should I back down the timing for the cross country drive and then up it again at BW on race gas? TIA , ed
Old Jun 26, 2001 | 04:01 AM
Boba-Fett's Avatar
New User
Default Re: Ignition timing w/Mugen ECU, 4-1, test pipe...? (zygspeed)
I think that would be a smart idea Zyg. Especially as you go across country and start to obtain some of the lower octane fuel.
Boba- who has seen 90 octane as premium before.
Old Jun 26, 2001 | 04:06 AM
ZygSpeed's Avatar
Default Re: Ignition timing w/Mugen ECU, 4-1, test pipe...? (Boba-Fett)
Yeah, thanks Boba.
I've driven through the west before... funny how they feel 89-90 is "premium" out around Colorado.
Could drop the stock computer back in, but then I'll have to re-do everything out there (which is what I'm trying to avoid).
One "odd" thing, there's much more power down low and therefore the VTEC kick is not as pronounced!?
Old Jun 26, 2001 | 05:00 AM
sgT's Avatar
sgT
altitude makes up for octane
vtec is not as pronounced because you are seeing a power loss when vtec
comes in. also, your x-country gas mileage will suck royally due to the
open loop ecu.
Old Jun 26, 2001 | 05:22 AM
ZygSpeed's Avatar
Default Re: Ignition timing w/Mugen ECU, 4-1, test pipe...? (sgT)
Thanks Stephen.
I owe you lunch some time.
umair
Oct 16, 2008 10:34 AM
95greenteg
Aug 21, 2007 04:00 PM
smash fascism
17
Sep 14, 2005 07:02 AM
douglas_be
Mar 24, 2004 09:18 PM
