ES Poly front tranny mount....
Old Apr 14, 2003 | 07:16 AM
Ef Whore's Avatar
Default ES Poly front tranny mount....
When I did my trans recently, I noticed the crossmember trans mount was shot. Taking out out/in made it worse....is this what causes the bucking when I let off then gas it in any gear? It's annoying having to lightly engage the throttle. Does ES make that mount for the a6? If so where can I order it from? Bucking is annoying as f&*k. TIA.
Old Apr 14, 2003 | 07:25 AM
dingusjt's Avatar
Default Re: ES Poly front tranny mount.... (Ef *****)
i think they only make the mount inserts for the CRX...and sorry to post jack but i actually have a complete unused set of motor mount inserts for 88-91 Civic/CRX for $15 + shipping
Old Apr 14, 2003 | 07:46 AM
keithv's Avatar
Default Re: ES Poly front tranny mount.... (dingusjt)
usually the rear mount is the cause of all the motor movement, but it could be different in your case if the front mount is totally gone.
ES makes inserts for the civic/crx front and rear mounts. pick up a set, but you probably want a new front mount since the ES mounts are only inserts in the stock mounts.
Old Apr 14, 2003 | 06:07 PM
Ef Whore's Avatar
Default Re: ES Poly front tranny mount.... (breaka_1_9)
Well the front mount is a stock mount. I dont want to do all 4 inserts, just the ones that will help with the bucking. So front and rear trans mounts? Do they install kinda like the lca bushings? (press out, pop in)
Old Apr 14, 2003 | 08:31 PM
kranked91dx's Avatar
Hep, I just put my cable trany in, so I felt like it was a god time to get the ES kit in, I started to put the rear in place, and due to stupidity and phoking around, I used to cut the front mount when I put the hydro trany in two year ago, fitting cause, now i'm back stock cable tranny and I test drive it with only the rear mount on, with the ES insert in the rear mount of course, VERY stable, it restraint a lot my engine movement, and I can drive it with no front mount without any problems, but be shure I will put it back in as soon as my MiG welder came back from my friend garage.
see ya.
Kraked.
Old Apr 15, 2003 | 03:44 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef ***** &raquo;</TD></TR><TR><TD CLASS="quote">Well the front mount is a stock mount. I dont want to do all 4 inserts, just the ones that will help with the bucking. So front and rear trans mounts? Do they install kinda like the lca bushings? (press out, pop in)</TD></TR></TABLE>
the es poly "mounts" are inserts. they insert into the stock mount so you don't need to remove anything. they are NOT a completely new mount like the LCA bushing case.
journeyquest
Mar 29, 2013 06:35 AM
TypeRod
Dec 7, 2011 02:45 PM
filtereds0ul
Dec 10, 2004 10:28 PM
SwissChEz82
Nov 17, 2004 10:20 AM
onyx00
Sep 24, 2004 01:00 PM
