what kind of hp gains can be expected from a d16y7 intake manifold to a d16y8 intake manifold?
Old Apr 14, 2003 | 06:45 AM
Smith Wise's Avatar
Default what kind of hp gains can be expected from a d16y7 intake manifold to a d16y8 intake manifold?
I currently have a d16y7, and I am thinking about swapping the intake manifold to a d16y8. As the title reads: What kind of hp gains can be expected from this swap? Would it be worth the time, effort, and money, in your honest opinion? Thanks for any help
Old Apr 14, 2003 | 07:06 AM
Irishweird00's Avatar
Banned
Default Re: what kind of hp gains can be expected from a d16y7 intake manifold to a d16y8 intake manifold? (
I already got mine, but didnt put it in yet... I would venture to guess at 10-20 horse, even more with a cold air..... I'm not sure but the sure size and shorter runners that that y8 has would just increase air flow greatly in the y7... def worth it in my opinion... since im doing it
Old Apr 14, 2003 | 07:07 AM
VTEC-DA's Avatar
17.6 HP
Old Apr 14, 2003 | 07:16 AM
thinkbrianthink bu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irishweird00 &raquo;</TD></TR><TR><TD CLASS="quote">I already got mine, but didnt put it in yet... I would venture to guess at 10-20 horse, even more with a cold air..... I'm not sure but the sure size and shorter runners that that y8 has would just increase air flow greatly in the y7... def worth it in my opinion... since im doing it </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC-DA &raquo;</TD></TR><TR><TD CLASS="quote">17.6 HP</TD></TR></TABLE>
come on guys...
i have the manifold on my d16y7. its not that big of an hp gain. granted i havent dyno'd my car with the new manifold but its not rocket science. now if you get the whole y8 head you might see 17-20hp.
imo the y8 manifold swap is more of a longterm strategy. if i were you id only swap it if you're planning on putting on a turbo. it will make the install alot easier.
Old Apr 14, 2003 | 07:17 AM
kommon_sense's Avatar
A stock y7 is rated at 106hp. A stock y8 is rated at 127hp. So, only a 21hp diff. The main diff between the 2 engines is the intake manifold and the vtec head on the y8. So I don't see how you could get 17.6hp gain by just swapping the intake manifold. Do you have a dyno chart to support this claim?
I would expect probably 5-8whp gains. It won't be night and day type of difference, but it will be quite noticeable. If you can get a good deal on the intake manifold, then it is definately worth the upgrade.
VTEC-DA's Avatar
I dont know about that guy above me, but I was kidding. I really dont know, but it cant be that much without the whole head package.
Old Apr 14, 2003 | 07:42 AM
wilsel's Avatar
1-3 hp.
Old Apr 14, 2003 | 07:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilsel &raquo;</TD></TR><TR><TD CLASS="quote">1-3 hp.</TD></TR></TABLE>
And where are you getting this number from?
Old Apr 14, 2003 | 11:34 AM
probably the butt dyno.
honestly, i would have to concur.
i just noticed a small difference up top. the car pulls harder towards redline where it used to fall off but its STILL a d16y7...
Old Apr 14, 2003 | 12:01 PM
seems like it would be reasonable to assume that to get the most out of this, you would need a vtec head as well.
Old Apr 24, 2003 | 05:36 PM
Smith Wise's Avatar
Default Re: (kommon_sense)
anyone else have something to add about performance, and/or price?
Old Apr 24, 2003 | 05:58 PM
Banned
Default Re: (Jswpstdoff)
I'm in the process of doing a swap..... ill let you know, but im sure it gains alot.
Old Apr 24, 2003 | 06:01 PM
gubo22's Avatar
New User
I added a y8 intake manifold to my y7 once and i was totally disapointed.
I would only recommend doing it if you get the manifold for dirt cheap.
Old Apr 24, 2003 | 06:02 PM
gubo22's Avatar
New User
better to get a final gear than anything else on the y7
Old Apr 24, 2003 | 06:05 PM
Ricey McRicerton's Avatar
Default Re: (gubo22)
Only reason Im doing it is so I can fit a bigger intake in my civic! (ITR)
EDIT: Not to jack this thread, but I figured the people willing to answer this could help me out. Ive got the complete Y8 mani (TB, injectors, fuel rail, brace and everything esle with it.) On the mani swap site that Im using it says you need a new throttle cable bracket. Do you need the one off of the y8 TB or what??? Any other suggestions to help the install??
Old Apr 24, 2003 | 06:07 PM
turbo_ef9's Avatar
Default Re: (Ricey McRicerton)
haha.. my nice blue itr intake
Old Apr 24, 2003 | 06:10 PM
Default Re: (eli_vang)
4 sure mang!!! Thanks for posting too...so I could make another one to email me....didnt want to have to keep checking this one!!!
Smith Wise's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Only reason Im doing it is so I can fit a bigger intake in my civic! (ITR)
EDIT: Not to jack this thread, but I figured the people willing to answer this could help me out. Ive got the complete Y8 mani (TB, injectors, fuel rail, brace and everything esle with it.) On the mani swap site that Im using it says you need a new throttle cable bracket. Do you need the one off of the y8 TB or what??? Any other suggestions to help the install??</TD></TR></TABLE>
Someone answer the man's question
Old Apr 24, 2003 | 06:14 PM
turbo_ef9's Avatar
yes you need one off the y8.. the one i did we ghetto rigged it with a 92-95 bracket..
Old Apr 24, 2003 | 06:27 PM
Banned
just so people don't get confused, its not the bracket its the spring, correct.
Old Apr 24, 2003 | 06:59 PM
Default Re: (Irishweird00)
Bump..thats what they're talking about when they say to change the spring on the Y7 TB???
Old Apr 24, 2003 | 07:05 PM
JasonBlackEJ1's Avatar
what about putting a z6 im and fuel system on a d16y6? how much hp would that give...if anyone has the slightest idea.
Old Apr 24, 2003 | 07:50 PM
madhatch's Avatar
the y8 mani and a gsr T body add about 10 hp. I hear the biggest increase is throttle response. The Y7 head and Y8 head are different, If you put the y8 head on a y7 motor it incresed compression drasticly. good luck.
BTW about 75 to 1oo on the manifold and 1 to 150 for the T body.
92civicfreak
15
Jul 6, 2007 05:59 PM
honda616
May 19, 2007 02:12 PM
IA95civicDX
May 12, 2005 07:22 PM
91 POS
Sep 12, 2003 01:33 PM
