Electrical Problem Lights.
Old Apr 14, 2003 | 06:28 AM
rschoener's Avatar
Default Electrical Problem Lights.
89 Hatch. My turn signals are flashing fast. I replaced the Flasher and all the bulbs in the front. They also look Kinda Dim. Any ideas on what to look for next?
Old Apr 14, 2003 | 09:40 AM
rschoener's Avatar
Default Re: Electrical Problem Lights. (rschoener)
What bulbs should i be using also? I put 194's in the bumper and corner lights.
Old Apr 14, 2003 | 12:22 PM
redEF's Avatar
one of my bulbs in the front went out and that made it flash really fast maybe one of your rear bulbs is out cusing the same thing?
Old Apr 14, 2003 | 05:17 PM
wickedEFguy's Avatar
yeah I had that same exact problem, check your bulbs usually if one of them isn't completely connected or if it's burnt out then it'll blink fast, Or you can check your blinker fluid HAHAHAHAH jk
Old Apr 14, 2003 | 05:20 PM
USDM 4G VTEC's Avatar
check bumper lights, corner lights and tail lights bulbs for blown, bad conection or corrosion... ur problem lies on the bulbs.... use WD-40 or some batt terminal wire brush to make sure they are clean
Old Apr 15, 2003 | 06:21 AM
rschoener's Avatar
Default Re: Electrical Problem Lights. (USDM 4G VTEC)
Does anyone Know what bulbs to use in my car. I have 194's all the way around. I think they might not be the right wattage.
gutted-dx
Jul 7, 2009 06:40 PM
EL Vap133
Apr 16, 2008 09:06 AM
ilikeric3
Aug 13, 2006 07:45 PM
PINKS
May 30, 2006 01:00 PM
DaNish
Sep 9, 2001 06:47 PM
