Is a five Lug conversion worth it with R rims....and for how much should it be?
Old Jun 25, 2001 | 09:15 PM
comptechgsr's Avatar
Default Is a five Lug conversion worth it with R rims....and for how much should it be?
i can get 2 CW Rims and 2 GM Rims from an integ type-r installed with the five lug conversion for $2000???
is it worth it, hopw much should it be for?
also, would this even look cool???
Old Jun 25, 2001 | 09:21 PM
OneThirtyEight's Avatar
Default Re: Is a five Lug conversion worth it with R rims....and for how much should it be? (comptechgsr)
SLOWLY put down the crack, unhand that prostitute, and walk OUT of the crackhouse. Carefully, regain reson, and get the same colored rims
Old Jun 25, 2001 | 09:22 PM
mickey513's Avatar
hell no, I can get a set of 17" with tires for $1000. And I can use the other thousand for like other things like a sound system or peformance parts such as a intake, headers, springs, koni shocks..........there is a better way of spending $2000 then just to make your car have a extra lug.....
Old Jun 25, 2001 | 09:26 PM
randyman's Avatar
New User
Default Re: Is a five Lug conversion worth it with R rims....and for how much should it be? (97blackteg)
2K sounds like a good deal for parts and installation included. i'd go for it. the CW and gunmetals should work for now. just get new wheels when u get the extra cash.
Old Jun 25, 2001 | 09:27 PM
crookedletterd's Avatar
New User
Default Re: Is a five Lug conversion worth it with R rims....and for how much should it be? (mickey513)
its not just having "1 more lug" its a better breaking system too right?
Old Jun 25, 2001 | 09:50 PM
Mr. Choi's Avatar
New User
Default Re: Is a five Lug conversion worth it with R rims....and for how much should it be? (integls98)
its not just having "1 more lug" its a better breaking system too right?[/QUOTE]
hey,
having one more lug bold does not mean anything in performance or in the braking system, all it means is add on weight and somewhat better on looks. if i was you, i would rather spend that money on something for the engine, l ike maybe cams, headders, crap like that. why would you want to spend that much money for one more lug bolt per corner??? i think that is a stupid investment in the world.
Old Jun 25, 2001 | 10:19 PM
EminemGSR's Avatar
Default Re: Is a five Lug conversion worth it with R rims....and for how much should it be? (ChoisVTEC)
I agree w/ Chois
Old Jun 25, 2001 | 10:28 PM
sLo B18b's Avatar
New User
if its just added wait then why would anycar have them??? its gotta have some kind of purpose... is it stronger somehow??? why does the itr have them and reg integras dont???
Old Jun 25, 2001 | 11:30 PM
blaze's Avatar
Default Re: Is a five Lug conversion worth it with R rims....and for how much should it be? (sLo B18b)
um, its not just one extra bolt. your definetly gettting better braking performance from a type-r(if the conversion is from a type-r). itr's have bigger and better braking components compared to gs-r's.
Old Jun 25, 2001 | 11:41 PM
Scorpaznatica's Avatar
New User
$2000 would be the approximate cost of modifying the stock suspension in terms of the difference between an ITR suspension compared to Non ITR's.
The former has; stiffer prings/dampers, bigger brakes, better tires than the latter.
So it all depends on whether the ITR springs/dampers and re010 tires (in good condition) are included in the package. Without both, it'll probably be wiser to buy aftermarket parts rather than doing the 5 lug conversion. Coilovers ($1000), Tires ($500) and Fastbrakes brake upgrade ($500)= better end result than a 5 lug conversion for about the same price
Installation isn't hard, you just need the time and the tools...cake.
Old Jun 26, 2001 | 04:59 AM
GSRwBOOST's Avatar
Default Re: Is a five Lug conversion worth it with R rims....and for how much should it be? (EKnine)
2000 isnt that much farther from a turbo kit!! much more respect from performance, than someone seeing you with rims...
Old Jun 26, 2001 | 05:40 AM
nerdish's Avatar
Default Re: Is a five Lug conversion worth it with R rims....and for how much should it be? (GSRwBOOST)
Well, to answer your questions..
1) No, it's not worth it.
2) $2000 would be a really good price, IF you had 4 of the same wheels..
3) Heed the advice of GSRwBOOST
Old Jun 26, 2001 | 08:44 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Is a five Lug conversion worth it with R rims....and for how much should it be? (nerdish)
Are you planning on racing the car on a road track? If so, it may be a good upgrade. If you just want to upgrade your braking ability, do a search for "fastbrakes" and his ITR Caliper conversion for the GSR. It'll save you about $1500 for R braking.
Old Jun 30, 2001 | 12:54 PM
guyuenvy's Avatar
i got my 5 lug for 2000 but included all gunmetal wheels
Old Jun 30, 2001 | 12:59 PM
guyuenvy's Avatar
Default Re: Is a five Lug conversion worth it with R rims....and for how much should it be? (guyuenvy)
this is what half and half would look like
Old Jun 30, 2001 | 01:05 PM
indy's Avatar
wow guy,
I was actually looking for a pic with gumetal rims on a WHITE GSR. They look pretty good. Has your braking improved?
One more thing, are the '97 rims for ITR lighter than the Gunmetal rims?
Indy
[Modified by indy, 5:06 PM 6/30/2001]
Old Jun 30, 2001 | 06:31 PM
guyuenvy's Avatar
i dont know about improved braking really dont feel a diference but have nothing to compare because i swapped to 5 lug after 3000 miles and my 1st oil change \D. I believe the weight is the same
Old Jul 1, 2001 | 06:36 AM
berkel's Avatar
I think the advantage to 5 lug would be that you CAN use ITR brakes, having 5 lugs vs 4 wouldn't make you braking or handling better, right??
IMHO it would be daffy to spend $2k on that, but hey, whatever floats your boat.
I think you could get BETTER braking and handling perf by getting lightweight aftermarket rims and an aftermarket upgraded brake kit. Stock ITR GM rims do look killer, but they're not much (if any) lighter than GSR wheels so you could do better.
Take care,
FB
reithhikaru
Mar 17, 2005 06:52 PM
buyselltrade
Oct 19, 2004 02:06 PM
B18C5er
Jul 8, 2004 05:10 AM
Boughetto
Jul 23, 2001 09:23 AM
