thermostat help!!
look behind the engine....you should see a water neck with hoses going to it......when you take this neck off (two 12mm bolts), you will see the thermostat......remember, you must first drain your coolant or you will spill that **** all over the place
philliedawg
13
Feb 8, 2010 07:29 PM
May 1, 2003 05:09 PM
