need some a6 block specs
Old Apr 13, 2003 | 08:56 PM
Quetzolcotl's Avatar
Default need some a6 block specs
main bearing cap torque lbs & rod cap lbs. oil clearance specs for rod and main bearings. thanks
Old Apr 13, 2003 | 11:27 PM
markw's Avatar
Default Re: need some a6 block specs (Quetzolcotl)
If you're that far into it, you should at least get the pdf shop manual that's floating around.
Old Apr 14, 2003 | 06:30 AM
Default Re: need some a6 block specs (markw)
what? any links? did search but couldn't find.
Old Apr 14, 2003 | 06:43 AM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quetzolcotl &raquo;</TD></TR><TR><TD CLASS="quote"> oil clearance specs for rod and main bearings. </TD></TR></TABLE> 0.002 in (0.05mm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quetzolcotl &raquo;</TD></TR><TR><TD CLASS="quote"> & rod cap lbs. </TD></TR></TABLE>23 ft-lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quetzolcotl &raquo;</TD></TR><TR><TD CLASS="quote">main bearing cap torque lbs</TD></TR></TABLE> separate caps on bridge 48 ft-lbs
one-piece cap assembly 33 ft-lbs
Old Apr 14, 2003 | 11:11 AM
keithv's Avatar
Default Re: need some a6 block specs (USDM 4G VTEC)
you can get a cheapo haynes manual that has engine building info/specs in it. its like $10 and worth it.
i would, however, get a helms. that manual cannot be beat for the money.
Old Apr 14, 2003 | 11:13 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: need some a6 block specs (breaka_1_9)
http://www.quickhonda.net
look under the garage and service manuals...i believe.
i dont think all the helms pages are hosted though.
Old Apr 14, 2003 | 09:03 PM
Default Re: need some a6 block specs (fastcrxsi90)
thanks guys
BLACK_DEL_SOL
May 20, 2006 12:44 PM
1point7db2
Mar 27, 2006 09:27 AM
johng
17
Mar 16, 2006 10:58 AM
CptMidway
Aug 1, 2005 10:58 AM
gulf imports
Jul 25, 2003 05:58 AM
