Skunk2 coilover making weird noise
Old Apr 13, 2003 | 05:38 PM
03Si's Avatar
Default Skunk2 coilover making weird noise
ok. i've had the coilovers for about 3 weeks on my 03 Si. Ever since i had them on, everytime i turn my wheels (on to drive way, or making U turn) they're making this twisting noise. it sounds like the springs are being twisted, and it's making the clanking noise. does anyone know what's causing them and how to fix it? also, is that a common problem with the new Si and Skunk2 coilovers?
Old Apr 13, 2003 | 06:07 PM
SjCiViCHB's Avatar
Default Re: Skunk2 coilover making weird noise (03Si)
the same thing happens on my brothers 02 civic. I think its cause the springs just turn. I dont know, but ive noticed though, that when we try to fix it, its not that bad, meaning its not so loud. Then when he hits a big bump the noise starts to get louder. Im still trying to fix the problem also.
Old Apr 14, 2003 | 09:12 AM
My_Blk_Si's Avatar
Default Re: Skunk2 coilover making weird noise (SjCiViCHB)
Alot of people with coilovers on the newer civics run into this problem...
Solution: Get in there and use GREASE, GREASE, and more GREASE...
This has solved the problem for ep owners 99.9% of the time.
P.S. Don't forget the obvious thing of making sure everything is seated properly.
Old May 21, 2003 | 04:35 AM
10K2HVN's Avatar
my car made sounds that sounded like that when my cv boot tore....
hehe hey look everyone in this thread is from CA or FL...
Old May 21, 2003 | 08:02 PM
sjracer's Avatar
Default Re: Skunk2 coilover making weird noise (10K2HVN)
Here, read my thread over at clubrsx. It tells you a lot about the quality of the SKunk2 springs.
Here's the link:
http://forums.clubrsx.com/show...76044
Grease up the front top hats real well with white lithium grease. That should solve your spring noise problem up front.
PS: It's not just adjustable springs that make this noise. Anything other then the stock springs make this noise. If you don't believe me go check out the hundreds of post over at clubrsx...late
backyarddc5
Aug 20, 2004 03:40 PM
