Shielded wires.
When you guys wired your vtec spool solenoid and oil pressure sensor, did you use 18 guage shielded wire? I didnt use shielded, I know what shielding does, I'm just wondering if you think its worth redoing it with shielded?
My car didn't run properly for over a year after I got my swap because the wires by the ECU weren't shelided properly.
I'd do it right if it were me.
well as far as "stock" is concerned, i believe you have it backwards. spool and oil pres do not use shielded. however, the o2 sensor and knock sensor technically use shielded. personally i didnt use shielded on any of my swap, and it runs perfect. also, out of ALL of the b16 swaps out there, i bet only 5% or less use shielded, just because they dont know any better. lucky for them it isnt really crucial. its really not necessary on our cars.
takeheed
Sep 3, 2002 12:30 PM
