Need Help on 5th Gen Accord Spring Rates ?
Old Apr 13, 2003 | 11:57 AM
Showoff's Avatar
Default Need Help on 5th Gen Accord Spring Rates ?
Koni shocks with Ground Control sleeve coilovers , is this a good spring rate .... 400lbs in front and 350lbs in back ? or should i get higher rates ? Note that i do have a system in back of the car ( Box, woofers, amps etc) Looking ofr stiff ride but nothing that will brake my bakc or should i step up the spring rates higher ?
Old Apr 13, 2003 | 01:00 PM
Nick M's Avatar
Default Re: Need Help on 5th Gen Accord Spring Rates ? (Showoff)
id rather have 400 front and rear
Old Apr 13, 2003 | 03:34 PM
Canonm7's Avatar
I'm got 450lbs up front and 375lbs in the rear.
Old Apr 13, 2003 | 09:56 PM
Showoff's Avatar
Default Re: Need Help on 5th Gen Accord Spring Rates ? (Canonm7)
With you guys having them how do they ride and wiht what shocks are you guys using ? and problems or downsides ?
Old Apr 14, 2003 | 07:46 PM
ApexiAccord's Avatar
hey showoff. so you deciding to ditch the tanabe setup? thought you were going to keep it. jes wondering how the sustec's rode were they smooth when u slamed it?
and did they go low? cuz rite now i have apexi worldsport and considering a upgrade.
20CiviC02Si
18
May 30, 2012 10:18 PM
Masterbobo
May 9, 2007 08:25 PM
MestizoRacer310
Aug 21, 2003 11:41 PM
MestizoRacer310
Sep 20, 2002 09:22 AM
