omg, a STOCK DX with 8lbs of boost running 14.3
Old Apr 13, 2003 | 11:15 AM
PhatHardy's Avatar
Default omg, a STOCK DX with 8lbs of boost running 14.3
holy crap, I went to a local car meet, and there was a dude with a red dx hatch, full interior totally stock, except some cut springs and some altezzas's, and he was running low fourteens on a regular basis, he had a turbo kit, i'm thinking a greddy at 8lbs non-intercooled, and he was running low fourteens, I can't believe anybody would ever turbo that d15, but he did and i can't believe it. Well i just wanted to see what you guys would think about it.
Old Apr 13, 2003 | 11:17 AM
-Gambit-'s Avatar
Default Re: omg, a STOCK DX with 8lbs of boost running 14.3 (PhatHardy)
i wouldnt believe it till i seen a time slip
Old Apr 13, 2003 | 11:25 AM
PhatHardy's Avatar
i saw the slip, and i rode with him, it was quite amazing.
Old Apr 13, 2003 | 11:28 AM
ekb18c's Avatar
it's very possible.
Old Apr 13, 2003 | 12:35 PM
nsxmatt's Avatar
Default Re: omg, a STOCK DX with 8lbs of boost running 14.3 (ekb18c)
I assume it's a EG DX then? If so even at 8lbs those 1.5 rods are asking for a quick exit of the block
Old Apr 13, 2003 | 01:10 PM
5thgen's Avatar
Default Re: omg, a STOCK DX with 8lbs of boost running 14.3 (nsxmatt)
they'll handle 10 easy.
Old Apr 13, 2003 | 01:35 PM
Steve Berman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">I assume it's a EG DX then? If so even at 8lbs those 1.5 rods are asking for a quick exit of the block </TD></TR></TABLE>
How so?
8 psi is only ~80HP.
The 1.5 Rods are the same as every other D series motor. They can handle 10-12psi if managed properly.
Old Apr 13, 2003 | 01:46 PM
-Gambit-'s Avatar
i feel it was those altezza taillights that gave him the extra boost he needs to run 14's
Old Apr 13, 2003 | 02:31 PM
Jon Black's Avatar
Default Re: omg, a STOCK DX with 8lbs of boost running 14.3 (gambit33)
Altezzas = 25 HP
Cut Springs = 15 HP
Turbo @ 8 PSI = 50 HP
Total = 90 HP
Actually 14.3 may be a little slow for a D15 with those mods.
Jon Black
Old Apr 13, 2003 | 02:49 PM
nsxmatt's Avatar
Default Re: omg, a STOCK DX with 8lbs of boost running 14.3 (DEViANT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEViANT &raquo;</TD></TR><TR><TD CLASS="quote">
The 1.5 Rods are the same as every other D series motor. They can handle 10-12psi if managed properly. </TD></TR></TABLE>
I was under the impression that d15b7 rods were much thinner than Z6 rods.
Old Apr 13, 2003 | 02:53 PM
SpoonMyHonda's Avatar
not bad
boostsohfast's Avatar
The rods in the d15 are not the same as the d16
Old Apr 13, 2003 | 02:57 PM
PhatHardy's Avatar
Default Re: omg, a STOCK DX with 8lbs of boost running 14.3 (boostsohfast)
ok, well either way the engine has like over 100k on it, so you guys think this thing is gonna blow soon? It's funny tho, even if he does blow it, he can probably get the same exact engine for free because it's such a pos, how many miles you think one of these engines can take with that much power on it.
Old Apr 14, 2003 | 03:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostsohfast &raquo;</TD></TR><TR><TD CLASS="quote">The rods in the d15 are not the same as the d16</TD></TR></TABLE>
Is this correct? I have torn apart an 88HF and DX engine and the rods looked identical to the a6 rods. And, we all know the A6 and Z6 have the same rods. The only difference that Im aware of as far as block differences, is the stroke on the crank.
Old Apr 14, 2003 | 07:45 AM
hatchback19's Avatar
I'm sure the d15 rods are differant, weaker.
Old Apr 14, 2003 | 07:49 AM
Engine Stroke, Rod, Rod Length Ratio
D16A1,A6,Z6,Y5,Y7,Y8 90mm 137mm 1.52
D15B1,B2,B8,B7 84.5mm 134mm 1.59
D15Z1 84.5 137mm 1.62
chart courtesy of AEM
88-95 DX/LX/CX all use a PM3 rod (134mm)
88-00 D16 motors use the same length rods, PM6 (137mm). The D16Z6 uses a PG6 rod and the D16Y5 (HX) uses a PE1, but they both supersede to PM6 rods. The only two rods that do not supersede from a PM6 is the P2P (D16Y8) and the PDN (GX motor).
The VX rod is comparable to a 1.6L rod in length. The number for the VX rod is P07.
Old Apr 14, 2003 | 08:16 AM
Evs-One's Avatar
Solbros Owns Me
what's so special about 14.3??? Sounds about right to me, if not a little slow.
I know a kid with a D16A6 in his EF, custom turbo kit running 10 psi, put down 178 whp, and kept up with my friends 240 with a SR20DET swap(he beat my friends 94 TT Supra last night!)...don't under estimate single cams....most of you are so ignorant
Old Apr 14, 2003 | 08:20 AM
Quad-Damag's Avatar
Default Re: omg, a STOCK DX with 8lbs of boost running 14.3 (Emerika)
thats dam good, i got 2k dx, and plan to run about 8 psi intercooled.
Old Apr 14, 2003 | 08:23 AM
Pengo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostsohfast &raquo;</TD></TR><TR><TD CLASS="quote">Engine Stroke, Rod, Rod Length Ratio
Old Apr 14, 2003 | 08:33 AM
jedubz
34
Aug 17, 2010 08:13 PM
urname7698
Honda Civic (2006 - 2015)
11
Oct 2, 2006 02:58 PM
bbrian
20
May 16, 2005 01:40 PM
Ragezero76
May 29, 2002 11:43 AM
fEAR9
May 1, 2002 09:21 AM
