Need Suggestions, Turbo Z6 overheating during cool downs...
Old Apr 13, 2003 | 10:21 AM
TommyV's Avatar
Default Need Suggestions, Turbo Z6 overheating during cool downs...
I have a D16Z6 with a greddy kit and a large Front Mount IC, its custom, takes up most of the grill space, and I'm thinkin that my radiator isn't catching enough air, only when I drive the car hard for a bit and then park it and let it run to cool down does the temp start to rise after 1-2 minutes, if I turn on the AC the temp DROPS immediately, so this is telling me that I'm not getting enough cooling to the radiator.... I am thinking a FAL slim line fan should help, but who has any other suggestions??
Old Apr 13, 2003 | 10:34 AM
BoostedED9's Avatar
Default Re: Need Suggestions, Turbo Z6 overheating during cool downs... (TommyV)
i ran 2 fans on my radiator. my intercooler is extremely big as well but the 2nd fan seemed to help... maybe an aftermarket radiator??
Old Apr 13, 2003 | 11:40 AM
TommyV's Avatar
Default Re: Need Suggestions, Turbo Z6 overheating during cool downs... (BoostedED9)
Yeah, I am thinking the increased flow rate of the FAL will help out alot, does anyone have one???
Old Apr 13, 2003 | 11:44 AM
ekb18c's Avatar
Make sure you have enough water/ anti-freeze in there w/o any air pockets, so make sure you bleed the system. (i forgot if the d16's have valve to release)
Then make sure your fan is working properly
Old Apr 13, 2003 | 11:52 AM
TommyV's Avatar
Default Re: Need Suggestions, Turbo Z6 overheating during cool downs... (ekb18c)
My cooling system is bleed tighter than a virgin's front middle pocket.
The stock cooling fan, it spins and doesn' t make strange noises, so I can only assume its working correctly...
Old Apr 13, 2003 | 12:09 PM
romeo619romeo's Avatar
get a better thermostat .. and also you dont need to idle your car over 1 minute the opil circulate more then that.. remember the cool down time is basicly to cool the turbo down and getting rid of the oil in the oil line for cooler oil.. try to idle your car over 30 seconds but less then 1 minute tho.. and also you might want to put your fan on a switch, so wire it up straight to the accessory and put the switch to the ground.. if you kno what im talking about ...im assuming you got a turbo timer ....so when the car turns off the fan will turn off as well that will solve all the problems and get a automatic radiator if you like cools a little better
Old Apr 13, 2003 | 12:13 PM
BoostedED9's Avatar
Default Re: Need Suggestions, Turbo Z6 overheating during cool downs... (romeo619romeo)
i put my water temp gauge where the sensor for the fan switch used to go on the thermostat housing and it takes for ever to read anything but it seems to work fine after a little bit
clutch6racerone
Aug 28, 2011 06:30 PM
jeffchaisi
Apr 5, 2005 02:30 PM
krayziehuh
Oct 19, 2003 01:39 PM
DsMWookie
Oct 13, 2003 09:31 PM
RICE POLICE SIP
30
Oct 6, 2003 05:19 PM
