Installing Skunk2's..help quick!
Old Apr 13, 2003 | 08:11 AM
GrandMarkie's Avatar
Default Installing Skunk2's..help quick!
I'm running these on KYB AGX's...just wondering if the threaded sleeve rests right on the perch. It looks weird since all that weight is resting on that since it's so narrow. The directions that came with it said to rest it on "a black steel ring" which is supposed to come w/ my stock setup, but I have nothing of the sort. Other ppl say just to rest it on the perch. Any info on this? Thanks!
Old Apr 13, 2003 | 09:07 AM
Stripped Honda's Avatar
99-0104
Default Re: Installing Skunk2's..help quick! (GrandMarkie)
let it sit on the perch but doesent it have O-rings to put under it ????
Old Apr 13, 2003 | 09:14 AM
Default Re: Installing Skunk2's..help quick! (Stripped Honda)
It has 0-rings, but arent those to put between the shock and the sleeve to keep it from rubbing?
Also, there is a metal circle piece that is part of the bumpstop (its tapered a bit) When I put the top hat on top this piece stops the hat from moving all the way down. The prob is, it wont let it move down enough where I can bolt the top bolt on. Do I still keep this piece? Thanks for the help
Duc_du
Suspension & Brakes
11
May 5, 2009 06:40 PM
generaltao
14
Apr 16, 2009 07:03 PM
maynards_ek
Dec 25, 2007 06:45 PM
chris215chris
Aug 17, 2003 08:18 PM
Zulu888
Nov 14, 2001 04:11 PM
