DIY: shift light?
Seems like you'd still need some kind of module to regulate the light...You can prob take apart one of those little shift lights and somehow wire up an LED that you can put anywhere.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThunderLips »</TD></TR><TR><TD CLASS="quote">Seems like you'd still need some kind of module to regulate the light...You can prob take apart one of those little shift lights and somehow wire up an LED that you can put anywhere.</TD></TR></TABLE>
yeah, you need some module. like above, you could spend the cash for a shiftlite then rewire the light to a smaller LED in your dash.
you can get an rpm activated switch, and hook it up to a LED light. i was planning on a DIY shiftlight for my car, and i was going to hook it up to the SRS light on the SI cluster...that would have been dope, as the SRS light is right under the needle on the tach. however, i got lazy, and i figured i already have too many wires under my dash, so it would be even more of a fire hazard, so i gave away my rpm activate switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airbag Club »</TD></TR><TR><TD CLASS="quote">you can get an rpm activated switch, and hook it up to a LED light. i was planning on a DIY shiftlight for my car, and i was going to hook it up to the SRS light on the SI cluster...that would have been dope, as the SRS light is right under the needle on the tach. however, i got lazy, and i figured i already have too many wires under my dash, so it would be even more of a fire hazard, so i gave away my rpm activate switch.</TD></TR></TABLE>
That sounds like a good idea, any info on this DIY mod?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumbii »</TD></TR><TR><TD CLASS="quote">i think razö came out with something like that..... its just called a shift light.... i forgot how much it goes for.....</TD></TR></TABLE>
razo wanted like 130$ for theres
what i found
what i found
how about the pivot shift lights? check out http://www.jdmspecperf.com
those look pretty sweet
RiSiNgDc2
Mar 8, 2006 09:37 PM
Junkyard2000
Nov 13, 2005 04:06 PM
5hipht_Ent
15
Dec 8, 2003 07:03 AM
