Motor is in
Old Apr 12, 2003 | 08:15 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Motor is in
So the day finally came, the motor is in and running. There's still some bugs to be fixed. The idle air control needs to be fixed, it's not idling perfectly. Other than that it's fine. I'm still getting use to the driving. It's a big difference from a stock 1.6L to a modified 2.0. Don't laugh, but I'm trying not to stall on first gear. I'm still trying to get use to the new clutch, flywheel, and everything all together at once.
I still retained my a/c and amazing I don't feel much of loss in torqe when it's on full blast. The ES mount inserts isn't causing that much vibration as I thought it would, maybe it's b/c I drilled holes into them to reduce the vibration. Well everything's together and I'm just waiting for bolt ons. Here's a sneak peek.
Modified by GapxGuy at 1:26 AM 5/5/2003
Old Apr 12, 2003 | 08:22 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Motor is in (GapxGuy)
Looks good . Enjoy.
Old Apr 12, 2003 | 08:23 PM
Echo7847's Avatar
Default Re: Motor is in (Archidictus)
hybrider's Avatar
yup, lookin good..good luck
Old Apr 12, 2003 | 08:33 PM
degooser's Avatar
so what exactly was done to the motor???
Old Apr 12, 2003 | 08:35 PM
Ivan's Avatar
senior gold member
Looks awesome
Old Apr 12, 2003 | 08:47 PM
94hatch's Avatar
should have cleaned out the engine bay before you put the motor in. Other than that it looks good.
Old Apr 12, 2003 | 08:56 PM
kent's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy &raquo;</TD></TR><TR><TD CLASS="quote"> It's a big difference from a stock 1.6L to a modified 2.0. </TD></TR></TABLE>
is that a b20? 2.0?
Old Apr 12, 2003 | 08:57 PM
playAho's Avatar
Default Re: Motor is in (kent)
have fun
Old Apr 12, 2003 | 09:02 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Motor is in (playAho)
B20VTEC?
Looks good
Old Apr 12, 2003 | 09:10 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Motor is in (FrostyDC4)
hope you didnt just throw a vtec head on a b20 block......hope you did your homework on it , good luck and looks great
Old Apr 13, 2003 | 03:13 AM
GapxGuy's Avatar
Default Re: Motor is in (TURSpoonEK)
Yes, it's a B20vtec and not I didn't just throw on the head.
B20B Block
B16A Head
B18C Tranny
11:1 JE pistons (85mm)
CTR cams
Skunk2 cam gears
Skunk2 intake manifold
AEM fuel rail and FPR
Portflow valve springs
ACT Flywheel
6 Puck Clutch
P73 ECU
CAI
ALL new gaskets and seals
Future add ons:
Spoon N1
4-1 header w/2.5 collector
270cc or 310cc injectors
Old Apr 13, 2003 | 06:52 AM
Noe Kozz's Avatar
How much you expect with this set up?
Old Apr 13, 2003 | 07:00 AM
JV's Avatar
JV
Who?
B20B Block
B16A Head
B18C Tranny
CTR cams
Skunk2 cam gears
ACT Flywheel
6 Puck Clutch
P73 ECU
CAI
Future add ons:
Spoon N1
No block girdle? What do you plan to rev it to? 8k?
Old Apr 13, 2003 | 09:39 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Motor is in (JV)
ya i was suprised not to see a girdle and an aftermarket oil pump
Old Apr 13, 2003 | 12:01 PM
GapxGuy's Avatar
I'm only planning to rev to 8,400 (stock CTR redline). I knew the B20 isn't good for high reving that's why I chose CTR cams. The oil pump is the same as the Type R so I kept it as that.
Old Apr 13, 2003 | 12:05 PM
underrated99si's Avatar
looking good have fun
Old Apr 13, 2003 | 12:20 PM
RoaringTurtle's Avatar
New User
have fun with your new setup
keep an eye on your driver's side mount
they are prone to breaking
I broke mine in less then 2 months after the swap
Old Apr 13, 2003 | 01:01 PM
joe_bocc's Avatar
Isn't the CTR redline 8900 rpm? I may be wrong though.
EDIT: oh yeah. Nice motor! Must be quite the difference between that and the stock 1.6.
Old Apr 13, 2003 | 01:52 PM
A D NOH's Avatar
I really don't know
Community Builder
sweet stuff gapxguy!! from what i remember your car looks really nice also.
What motor did you take out of your car?
Get some dyno tuning, it does wonders
Old Apr 13, 2003 | 01:59 PM
TheJediMex's Avatar
Default Re: Motor is in (SEK SEE)
sweet install..
any pics of the swap while you were doing it?
Old Apr 22, 2003 | 09:53 PM
GapxGuy's Avatar
Default Re: Motor is in (JdmTeg98R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmTeg98R &raquo;</TD></TR><TR><TD CLASS="quote">sweet install..
any pics of the swap while you were doing it?</TD></TR></TABLE>
No, I didn't want to get the camera greasy. Here are a couple more pictures I took today.
Modified by GapxGuy at 1:24 AM 5/5/2003
Old Apr 22, 2003 | 09:55 PM
Evs-One's Avatar
Solbros Owns Me
Old Apr 22, 2003 | 10:03 PM
sshaikh01's Avatar
Very nice.
you got cam gears before the header
Old Apr 22, 2003 | 10:04 PM
93EH6
Guest
Posts: n/a
Default Re: Motor is in (joe_bocc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joe_bocc &raquo;</TD></TR><TR><TD CLASS="quote">Isn't the CTR redline 8900 rpm? I may be wrong though.
EDIT: oh yeah. Nice motor! Must be quite the difference between that and the stock 1.6.</TD></TR></TABLE>
CTR Redline is 9000, now that all you uneducated people know that. I will have to say it looks nice
