anyone had a fuel pump relay problem?
First off, I don't know if there is a relay for the fuel pump? Anyone know? Here is my problem. I can turn the car to the on position, I will hear a click under my dash and the fuel pump prime, call will crank, no problems. If I shut it off and try and crank again, nothing, no click, no fuel pump coming on, nothing. I have had to wait as long as 3-4 hours before I could get it to come on again. I am totally confused. straight wire the pump, works like a champ. obvioulsy fuse is good cause it will work sometimes. I am about out of idea's of what to do........any help guys?
I think I have verified that the main relay controls the fuel pump............anyone help verify this? anyone ever have this problem?
it is a grey colord box in my hatch. had same problem after my swap. I ended up getting one out of a junk yard integra. check the pump to mine went shitty once from a clogged filter in the tank. good luck with it
written by THE GUY (forgot to change screen name, sorry, not my PC)
i had teh exact same problem only a relay in my underhood fuse box was bad not for sure which one it is becuase my box doesnt have a label
good luck
good luck
sounds like you need to replace the main relay. (mitsuba) You can buy it from napa from 45 bucks, or grab one from the junkyard and take your chances. Check out this site.
http://www.markl.f9.co.uk/howt...y.htm
btbomb
Oct 10, 2007 03:22 PM
