d16z6 swap no spark no run...any thoughts
it is a 91 si, and i am using the si dis, and a pg7 ecu..i put a paper clip in the and held next to the block no spark..i checked the coil and within specs..please help would like to hear this run, also using z6 manifold and obd0 injectors and restior box..
-sean
-sean
i checked spark plugs by sticking a paper clip in the boot and held it close to the block. thermostat housing grounded..the pg7 i will have to check...is there a certain number i need to look on it to see what year it is from...how do i check to make sure the ecu is working.
Check the ignitor, a friend of mine has already had the same problem, and that's what it was. (It took him 2 hours to check everthing before figuring it out.)
SargeSlapnuts
Mar 3, 2008 04:28 PM
