Need help. Come on, someone's gotta know...
Old Apr 12, 2003 | 03:55 PM
Mike K's Avatar
Default Need help. Come on, someone's gotta know...
The motor is a ITR motor with Endyn 12:1 pistons, header, stock cams, stock head port, chipped P28 Skunk program.
We installed TWM ITBs on it today.
310s ran like ****. Too much black smoke.
270s ran decent, but still sputtering and smoke.
240s ran okay.. no smoke, but still some hesitation.
We've tried different fuel pressure settings from 19psi up to 40psi to no avail.
The plugs were fouled, so we put new plugs in and it still sputtered. Could it be the Skunk program? Is there any unknown trick that I haven't heard of?
Also, what should we do about the PCV system? The car does not have an aftermarket catch can. Is it a necessity?
Also, does anyone know how to cure the problem with the throttles sticking occasionally? Different spring? Are they available from TWM?
Thanks for any help. Much appreciated. Keep in mind I've been out of the game for a long *** time, and I am a dumb *** when it comes to individual throttle bodies. I'm a rookie on this.
I've helped otu mad people with advice, so maybe someone can throw me some knowledge. Thanks again!
Old Apr 12, 2003 | 03:58 PM
topspeed86's Avatar
Default Re: Need help. Come on, someone's gotta know... (Mike K)
Thanks mike maybe we can figure these things out
Old Apr 12, 2003 | 08:21 PM
Kengs's Avatar
You must be slipping kiddo
Old Apr 12, 2003 | 10:03 PM
Shark Tank's Avatar
Default Re: Need help. Come on, someone's gotta know... (kengs)
ok, skunk program runs really rich
next,
TWM uses a newer spring/chain(whatever it is) to keep the throttle plates from sticking open. they fixed the problem after many people reported this happening.
if those are jared's itb's those are the older version, so you would probably need to call TWM and get the newer piece.
Old Apr 13, 2003 | 12:10 AM
Hukd Up's Avatar
Mikey! How I've Been looking for you!!!!
I'm gonna send you an IM
!!!!!! hope you reply!!!!!
Jason
Old Apr 13, 2003 | 12:06 PM
topspeed86's Avatar
ttt
Old Apr 13, 2003 | 12:37 PM
SurferX's Avatar
Default Re: Need help. Come on, someone's gotta know... (topspeed86)
Using a preprogrammed off the shelf ECU program, of course larger injectors will run too rich. That needs to be tuned for real.
Old Apr 13, 2003 | 05:48 PM
sgT's Avatar
sgT
Default Re: Need help. Come on, someone's gotta know... (Shark Tank)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shark Tank &raquo;</TD></TR><TR><TD CLASS="quote">TWM uses a newer spring/chain(whatever it is) to keep the throttle plates from sticking open. they fixed the problem after many people reported this happening.
It didnt fix the problem. only made MORE problems.
you need to get a programmable ecu.
Old Apr 15, 2003 | 01:13 AM
Mike K's Avatar
Default Re: Need help. Come on, someone's gotta know... (sgT)
2 more weeks steve. we gotta meet up and drink a beer or six.
i got your parts. later.
Old Apr 15, 2003 | 01:14 AM
Mike K's Avatar
anyone else got a suggestion?
Old Apr 15, 2003 | 06:05 PM
sneakychaos's Avatar
with all due respect, typically you wont find anyone who knows the answer to publicly provide it - as its how some of the more experienced tuners make their money. understandable, and again all due respect to all.
Old Apr 15, 2003 | 06:06 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Need help. Come on, someone's gotta know... (sneakychaos)
Mike, my buddy wants to buy your car if it's for sale. I know the Toda's were for sale a while ago. Maybe the whole car is now.
Take care brother
Old Apr 15, 2003 | 06:09 PM
Shark Tank's Avatar
i already mailed him the answer and any tuner worth a **** should always be willing to help his current and former customers out with advice or knowledge. Thats why cheetah are vapor trail are top notch
Old Apr 16, 2003 | 01:54 PM
topspeed86's Avatar
thanks Shark tank for all your help.
Old Apr 16, 2003 | 01:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shark Tank &raquo;</TD></TR><TR><TD CLASS="quote">i already mailed him the answer and any tuner worth a **** should always be willing to help his current and former customers out with advice or knowledge. Thats why cheetah are vapor trail are top notch </TD></TR></TABLE>
customers = spend their $ to get the service... hence my post. no harm intended, calm down.
Old Apr 16, 2003 | 06:13 PM
Shark Tank's Avatar
no problem, just saying if you are going to be a good tuner, you shouldnt charge an arm and a leg for just some help and answering a few questions. should they charge good money for their expertise on the dyno and building and installs, yes...but knowledge should be shared in most cases
Old Apr 17, 2003 | 04:13 PM
Mike K's Avatar
i agree with both of you guys. you both have valid points.
thanks again for all the replies.
TurboKneeGrow
Apr 19, 2008 03:02 AM
SpoonEk253
13
May 10, 2007 05:03 AM
gSIr
15
Apr 19, 2006 11:15 AM
brokenojoke
May 29, 2005 07:55 AM
krazie1
Mar 24, 2004 08:25 PM
