Can't remove crank pully bolt on crankshaft to change my timing belt.
Old Apr 12, 2003 | 03:31 PM
GQ 05YellowEVO8's Avatar
Default Can't remove crank pully bolt on crankshaft to change my timing belt.
This afternoon I tried to clean up the entire area wehere the timing belt is from when it got shredded. i put the car in 5th gear, had my little brother step on the brakes and then with a torque wrench set to 150 ft./lbs I couldnt remove the crank pully bolt. i would be turning the thing and the wheels would just rotate.
How could I get it off w/o using air tools? by the way the timing belt is already off since I cut it out with a scissor.
help!
Old Apr 12, 2003 | 03:53 PM
92TypeR's Avatar
FSAE
Default Re: Can't remove crank pully bolt on crankshaft to change my timing belt. (13 Sec GSR)
Do you have a pulley holder thing (don't know the exact name)? They are inexpensive and help if you don't have air tools. Otherwise try sourcing an electric impact.
Its nearly impossible to do the job without some sort of impact or pulley holder thingy.
Old Apr 12, 2003 | 04:00 PM
arren123's Avatar
Unless you have a real powerful air impact gun, you won't be able to get it off. Don't even bother with the electric impact wrench, it's not powerful enough. I've tried it before.
Best bet is the moroso bar, jackstands, 10 inch 1/2" extension, 3 foot breaker bar and a nice galvanized 3 or 4 foot pipe to get some leverage. It also helps if you are heavy and not as skinny as me.
Old Apr 12, 2003 | 05:02 PM
WiggiE's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13 Sec GSR &raquo;</TD></TR><TR><TD CLASS="quote">then with a torque wrench set to 150 ft./lbs I couldnt remove the crank pully bolt.</TD></TR></TABLE>
Just FYI, don't use your torque wrench to remove bolts. Go get a breaker bar.
Old Apr 12, 2003 | 06:34 PM
GreenD's Avatar
Default Re: Can't remove crank pully bolt on crankshaft to change my timing belt. (WiggiE)
screwdriver in the flywheel & pipe extension for the breaker bar.
Old Apr 12, 2003 | 06:47 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiggiE &raquo;</TD></TR><TR><TD CLASS="quote">
Just FYI, don't use your torque wrench to remove bolts. Go get a breaker bar.</TD></TR></TABLE>
ROFL.... no kidding
Good way to break a handy tool
Old Apr 12, 2003 | 07:23 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Can't remove crank pully bolt on crankshaft to change my timing belt. (P1mpSlap)
never ever ever use a torque wrench to loosen bolts. Breaker bar or impact wrench. Also when working on my friend's car, putting a screwdriver (or two) in the flywheel was much easier than trying to put it in gear and stand on the brakes.
Old Apr 12, 2003 | 07:37 PM
Default Re: Can't remove crank pully bolt on crankshaft to change my timing belt. (GreenDestiny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenDestiny &raquo;</TD></TR><TR><TD CLASS="quote">screwdriver in the flywheel & pipe extension for the breaker bar.</TD></TR></TABLE>
That sounds like a clever idea....I should try that.
By the way, where do I go about putting in the screwdriver into the flywheel?
Old Apr 12, 2003 | 07:50 PM
GreenD's Avatar
By the way, where do I go about putting in the screwdriver into the flywheel?</TD></TR></TABLE>
theres a thin black metal cover that u have to remove. youll see it.
Old Apr 12, 2003 | 10:53 PM
igyloo's Avatar
find an impact, MAC 1/2" impact worked for me
JDM_SOHC
27
Sep 28, 2009 09:05 AM
endeavor40ft
May 24, 2007 04:57 AM
optoomistic
Nov 1, 2003 09:27 PM
AmauryR
Jan 22, 2002 01:48 PM
D-SPEED
Sep 2, 2001 08:04 PM
