Will this turbo fit?
I recently picked up a small T3 turbo for cheap from a friend. I just noticed that on the exhaust housing, the flange is not just a rectangle. It's a rectangle that has a circle in the middle. I can also get ahold of a revhard manifold. What will I have to do to make the turbo fit on to the revhard manifold. I've never seen a flange with a circle in the middle of it before. What are my options?
Yeah, i found out the turbo is off a Volvo. So you are just going to weld right where there is that little lip around the circle, and bolt it to the manifold? How much would it be to get it machined to the right shape? Those are some good options for me. Whichever is the cheapest route, I guess i'll go that way.
This is a Volvo turbo.
a/r .48ex-.42int
You can buy this type of flange at your turbo shot and weld it to the max-rev manifold!!
Modified by Antho303T at 3:31 AM 4/15/2003
a/r .48ex-.42int
For the record, only the Volvo turbo looks like that. The Saabs have a normal T3 flange.
My boy Wes has a Volvo T3, he said he had a gasket for it to help it seal? He'll be here about noon, I can ask for more info, maybe get pics.
you can make a flange that fit's it you have to use longer bulits and gust to the size and shape of the turbo and manifold. I seen them do on a crx in honda tuneing. that would be the best thing to do.
