MPFI question
Old Apr 12, 2003 | 11:35 AM
uneek4dr's Avatar
Default MPFI question
Ok i was pokin around under the dash at the ecu gettin ready to clip all necessary wires and such. well in the write up it says use the unused pins from b2 or b11......i have wires running from those two pin locations...... i have NO wires at pin location b9, b10, b12.........and how are you suppose to "use the pins" i have the lil pin part that sticks out from the ecu in EVERY spot there isnt one that i would have to move.....so basically what im asking is do i just go ahead and add the wires to where its telling me? lol I dont understand how to take the "pins" from one spot and use them in another since i have lil pins in every location in the ECU. only thing i need is the clip that the pin would slide into that is attached to the wire correct? i REALLY need an answer ASAP before the nice weather goes away haha. I got everything else ready to go just gotta do the ECU mod and its ready to go in. Thanks!!!!!
Old Apr 12, 2003 | 12:16 PM
Aron Parsons's Avatar
Default Re: MPFI question (uneek4dr)
When it says to re-use the pins, basically you're going to cut the wire for the pin you're going to be using (you will have extra wires in the bundle not going to anything, just tape them off and put them out of the way.). This way you have the pin connected to the old wire, but with enough wire left over to put your new wire on. Be sure to leave enough extra wire so you can solder it to the new wire running where it needs to go.
The un-used pins are pins with wires that aren't going anywhere in the car.
Old Apr 12, 2003 | 02:52 PM
uneek4dr's Avatar
Default Re: MPFI question (Aron Parsons)
thanks. so i shouldnt be afriad to cut the wires? lol it runs back into the group of wires but where it goes if anywhere im not sure...oh well thanks again!
prelude182
Mar 14, 2011 09:29 AM
808DA
Nov 23, 2009 05:51 PM
jfksol
Nov 21, 2005 11:44 AM
EE_Chris
Dec 2, 2003 09:40 AM
Firedrake
Oct 30, 2002 04:56 AM
