4th gen mirrors
Old Apr 12, 2003 | 10:22 AM
Starrman85's Avatar
Default 4th gen mirrors
is there a difference between the 2 door and 4 door mirrors on the 4th gen accord? i've been on different sites and such, and they all refer to 4dr mirrors. do they make a 2dr mirror? or are they the same?
Old Apr 12, 2003 | 11:17 AM
rustyeleio's Avatar
Default Re: 4th gen mirrors (STARRMAN85)
they have different part numbers at < http://www.hondaautomotiveparts.com/ >. you should look for your exact year and model (then compare to another model) at the website to be sure. yu might want to look for it at the junk yard also, you'll save lots of money. if you are getting a power mirror from the junkyard, better check to make sure it works or get some kind of return policy.
Old Apr 12, 2003 | 07:53 PM
Starrman85's Avatar
Default Re: 4th gen mirrors (rustyeleio)
that sucks, sometimes i feel like i get gipped with my 2dr when they dont make parts for it. THe reason i was wonderin what the difference was is because i wanna get some M3 style mirrors on ebay, but they all say 2dr. o well.
Old Apr 13, 2003 | 12:53 AM
.bagged's Avatar
if for some reason they are a hair different usually you can replace the surroundings to adjust to the 4-door version for cheap.. for example, as you know there are not many tail light options for your 2-door, so take the trunk lid off a 4-door to accomidate. the same can be done with your mirrors, just not to the effect of new doors obviously.
Old Apr 13, 2003 | 06:48 AM
ZigenBallz's Avatar
Default Re: 4th gen mirrors (bagged93accord)
5thGen M3 mirrors work also.....with some minor dremel modification. No need to redrill if done right.
I'd try the 90-93 2dr versions....they have the chance of needing less modding if any at all to fit.
PreludePhill
Jul 6, 2007 03:23 PM
integlude
Jan 15, 2004 12:11 PM
gvr4-330
Aug 29, 2002 03:47 PM
