How the hell do you remove the blower motor?
I finally got a new resistor and I tested it and it works.... Ok now I need to get the blower motor out of the car. Any ideas? I have all of the bolts loosened up and I can't wiggle the damn thing out of there.... I can't pull the AC out anymore becasue I would have to remove it all togher to remover the evaporator. Any help? Tips? Thanks guys!
the blower motor is under the dash, closest to the passenger side fender. Are you talking about the radiator fan or condensor fan?
I know where the blower motor is, I just can't seem to get it out. Do I have to remove the AC condenser to remove the blower motor and if so can this be done without leaking R134? Thanks!
I just replaced mines 2 weeks ago.. 3 screws and a plug are the only things holding it in. Its a bitch to take out but I just wiggled the hell out of it until it fell. Putting it back in was a bigger bitch. You have to put the front part in first and try to stuff as much of it as you can back up there. Next time I do that Imma just take out the ecu box cause it hella in the way. Oh and folding back the carpet helps a little too. Good luck man.
johnclaunch
Sep 8, 2004 10:59 AM
