Integra Seats in a CRX
Old Jun 25, 2001 | 06:38 AM
wronghand's Avatar
Default Integra Seats in a CRX
Will a set of seats out of a 95 - 00 integra bolt right into an 88 CRX? If not how much modification would I be looking at to make it fit? Thanks for the help.
Old Jun 25, 2001 | 08:52 AM
tysf's Avatar
Default Re: Integra Seats in a CRX (wronghand)
no they won't bolt right in
use your stock rails and then make some custom brackets to attach the rails to the integra seats
thats how i did it with my crx seats. good luck
Old Jun 26, 2001 | 05:31 AM
4G-CIVIC's Avatar
New User
Drill a second hole of equal size above the the rear inner bracket on each seat so that you now have a set of holes that looks like an 8(remember that you need this on the rear inner bracket location "only"). Thats all I need to fit 97 leather into my sedan. It does take a little muscle to get the brackets lined up but my seats slide straight and have worked for about 3/4 of a year just fine.
Old Jun 26, 2001 | 01:57 PM
wronghand's Avatar
Default Re: Integra Seats in a CRX (4G-CIVIC)
One more question: Will 91 CRX Si seats bolt right into an 88 CRX DX? It seems like they would but I am not sure?
Thanks again for the info.
Old Jun 26, 2001 | 02:22 PM
crux131's Avatar
I beleive the 88'-89' seat brackets were slightly different from the 90'-91's.
You may be able to swap the brackets from the bottoms of the seats though.
Old Jun 26, 2001 | 05:17 PM
Senses Fail y0!'s Avatar
I should know better
Default Re: Integra Seats in a CRX (crux131)
yeahthat.
Old Jul 2, 2001 | 10:10 AM
crxgurlllll's Avatar
Try swapping the whole lower pan(that way youre brackets are sure to mount up) You also may need to swap the side levers
Ive seen GSR leathers in a crx and thats what the guy had to do
Old Jul 2, 2001 | 12:25 PM
91sifreak's Avatar
New User
Default Re: Integra Seats in a CRX (eraser)
Eraser is right, a friend of mine did that same interior swap and he said that he swapped out the whole underside and then there was nothing else to worry about. He said something about the rail need a new bolt hole drilled in it but it took him only and hour or so to do, so for what it's worth...
CrxKid88SiR
Apr 11, 2015 08:24 AM
fin781
Jan 7, 2010 03:09 PM
JDMgunmetalCRX
Mar 21, 2009 04:38 PM
dustin
Sep 6, 2001 02:40 PM
vtecrx
Aug 7, 2001 03:58 PM
