Anyone install a 94+ integra LS/GSR cluster in there CRX??
I have one sitting at home and was wondering if anyone tried this... I've seen it on someone's car before and it look really nice!!!
remember that 92+ civics and 94+ integras, used electronic speedo pick up...so you will need to drop one in there before doing anthing....also if you have a Y1 tranny (since it uses elec.) not cable it should be easier.....
but why....
but why....
i have it in my crx. you need to have a 90 cluster cover. ut off the "ears of the cluster. make some kind of brackets. match all wiring up and it works perfect. im using a vss. no pics right now though.
Yes please post a pic....
Also, what motor are you running? I can see this working unless your using the stock motor...
you have the whole wire harnass... just cut the wires and resolder the plugs... if you need a tech manual, i can get you 1 too with the wire colors...
I had a GSR cluster in my old 89 Civic Si hatch about 2 years ago. Ran a GSR motor, with complete GSR inside wiring harness, and GSR engine harness. I mean complete from headlights to taillights. Then i just used the GSR dash harness, and like the other guy said, cut off the leg pieces on the sides and the top, and put the baby in the cover thing. Look great, but didnt sit perfectly straight. Worth the effort in my book because i got all the wiring pretty cheap.
As for using your stock harness, i have no idea. You will need the electric VSS. BTW the electric VSS will fit any of the trans, you just have to wire it up.
dingusjt
Nov 19, 2008 10:12 AM
SiR Inspired ED7
May 19, 2005 09:42 PM
HamiltonRex
10
Oct 4, 2004 02:22 PM
