B16 Axle, anyone used a ball joint seperator?
Old Apr 11, 2003 | 08:47 PM
ScottEK's Avatar
Default B16 Axle, anyone used a ball joint seperator?
All the times in the past I have never had to seperate a ball joint. I normally take off the upper bolt of the lower control arm and most of the suspension bolts, this allows the hub to swing around and let the axle in. Now with the b16 in the passenger side axle blocks that upper bolt so I have leave the lower control arm on. I need to disconnect the lower control arm at the hub side, I'm guessing you use a fork type tool, I tried to use a 2 armed puller with no luck. Any help or tips on how to use that fork tool, does it hurt that rubber boot?
Old Apr 11, 2003 | 10:08 PM
RCautoworks's Avatar
Default Re: B16 Axle, anyone used a ball joint seperator? (beta13)
Yes you can hurt the boot, make sure you lube the boot up well. And what I normally do with the fork is I put it in the spot I need to seperate, I hammer is alittle, either that will knock it apart or I will pry up and down alittle and that usually works.
Old Apr 11, 2003 | 10:30 PM
ScottEK's Avatar
Default Re: B16 Axle, anyone used a ball joint seperator? (90blackcrx)
You just put the fork right below the boot right? I dont understand what it is actually seperating.
Old Apr 11, 2003 | 10:41 PM
smokey2.0's Avatar
loosen the lower ball joint bolt, but don't take it off. using a heavy hammer(5-7lbs) strike the lower control arm, above the ball joint just below the rubber boot. a few strikes with the hammer, will separate the ball joint without the risk of damaging the boot or the threads on the bolt!
Old Apr 11, 2003 | 11:10 PM
Rywire's Avatar
Default Re: B16 Axle, anyone used a ball joint seperator? (smokey2.0)
I always use a big crow bar, and put it between the lca, and knuckle, and jerk it up. It works great. Ryan
jmvtec05
Honda Civic (2001 - 2005)
Aug 11, 2012 09:25 PM
Vp Special K
17
Jan 6, 2004 02:08 PM
girl m3chanic
Jul 12, 2003 10:48 PM
munscher
Jun 16, 2003 06:34 PM
XEF-9X
18
Aug 15, 2002 10:31 PM
