Anyone attempt a Do-It-Yourself maplight?
Old Apr 11, 2003 | 06:30 PM
ScaleExtric's Avatar
Default Anyone attempt a Do-it-yourself Maplight?
Saw someone do this on a Civic...and just wondering if anyone of you have directions or how-to's on doing this project?
I am so used to my ladys integra with the map light..however Im sure you all you know the R/RS dont have em...
Anyone do this?
Thanks
Old Apr 11, 2003 | 10:51 PM
tC_Dragon's Avatar
Default Re: Anyone attempt a Do-it-yourself Maplight? (ScaleExtric)
whoa... really? i never knew that the R & RS didnt have em.. oh ****.. hahah.. ya learn something new everyday!
Old Feb 27, 2006 | 01:06 AM
midniteweezer's Avatar
Default Re: Anyone attempt a Do-it-yourself Maplight? (tC_Dragon)
https://honda-tech.com/zerothread?id=454651
This is for maplights in a civic, tho in a teg should be the same. One can be put in by tapping off of the dome light, slide a wire through (if you dont have a sunroof. You will want to make the wire into a Y because the Teg had two lights, so individual power for each switch.
Old Feb 27, 2006 | 01:34 AM
greasemonkee's Avatar
Default Re: Anyone attempt a Do-it-yourself Maplight? (midniteweezer)
Here's a doityourselfer:
Got a little crazy with the LED's - 20,000 mcd's each 48 total.
Bordom sucks
Old Feb 27, 2006 | 07:30 AM
itr1244's Avatar
Default Re: Anyone attempt a Do-it-yourself Maplight? (greasemonkee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greasemonkee &raquo;</TD></TR><TR><TD CLASS="quote">Here's a doityourselfer:
Bordom sucks </TD></TR></TABLE>
that's actually pretty sweet<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tC_Dragon &raquo;</TD></TR><TR><TD CLASS="quote">whoa... really? i never knew that the R & RS didnt have em.. oh ****.. hahah.. ya learn something new everyday! </TD></TR></TABLE>
welcome to 1997
why doesnt the R have it?? for weight reduction ? lol that saves us 1/2 lbs woah
Old Feb 27, 2006 | 09:18 AM
ITR640's Avatar
Default Re: Anyone attempt a Do-it-yourself Maplight? (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">
why doesnt the R have it?? for weight reduction ? lol that saves us 1/2 lbs woah </TD></TR></TABLE>
That, and I can't remember the last time I had to read a map on the track.
Old Feb 27, 2006 | 09:26 AM
JjuuN R's Avatar
Default Re: Anyone attempt a Do-it-yourself Maplight? (ITR640)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR640 &raquo;</TD></TR><TR><TD CLASS="quote">
That, and I can't remember the last time I had to read a map on the track. </TD></TR></TABLE>
hahah!!!
Old Feb 27, 2006 | 10:16 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Anyone attempt a Do-it-yourself Maplight? (JUN.R)
If someone can come up with a procedure to retrofit the OEM cruise control from a GS-R into an ITR, even though it takes hundreds of dollars of parts and 40+ hours of labor, I'm sure someone can do the same thing to retrofit the OEM map lights from a GS-R...
Old Feb 27, 2006 | 11:02 AM
BudMan's Avatar
Default Re: Anyone attempt a Do-it-yourself Maplight? (nsxtasy)
Can you say "flash-light"? hehehe
Old Feb 27, 2006 | 12:18 PM
MatrixShark's Avatar
I just bought an extra map light...
I'll let you know if I ever get around to installing it... after ther carputer, and the HID's and the... you get the idea.
Old Feb 27, 2006 | 12:32 PM
dwolsten's Avatar
Default Re: (MatrixShark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatrixShark &raquo;</TD></TR><TR><TD CLASS="quote">I just bought an extra map light...
I'll let you know if I ever get around to installing it... after ther carputer, and the HID's and the... you get the idea.</TD></TR></TABLE>
Sorry to thread-jack, but do you have any threads about your carputer, your plans for it, etc.? I'm planning to do one as well, and your list of other plans actually corresponds to mine as well. I'm 100% complete on the parts for a HID retrofit (except I'm using Bosch bixenon projectors), but I haven't started on the carputer at all, and the K20 is still a dream.
Back on-topic, it seems to me it should be pretty easy to buy a regular Integra maplight, either used from someone parting their car out, or at acuraparts247.com, and just install it by wiring it into the dome light as someone else posted. I imagine you'd have to cut a small hole in the headliner, and hopefully any nuts needed will already be welded in.
Old Feb 27, 2006 | 06:32 PM
machgo5go's Avatar
Default Re: Anyone attempt a Do-it-yourself Maplight? (neo_)
Here U go!
Old Feb 28, 2006 | 12:48 AM
EnjoyTheRideDC2's Avatar
Default Re: Anyone attempt a Do-it-yourself Maplight? (machgo5go)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machgo5go &raquo;</TD></TR><TR><TD CLASS="quote">
Here U go! </TD></TR></TABLE>
LOL....
Old Feb 28, 2006 | 12:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScaleExtric &raquo;</TD></TR><TR><TD CLASS="quote">Saw someone do this on a Civic...and just wondering if anyone of you have directions or how-to's on doing this project?
Anyone do this?
Thanks</TD></TR></TABLE>
It would seem pretty easy in my eyes.
-Get yourself a Integra Map Light
-Remove your headliner
-Cut an opening that will accomodate the housing of the maplight
-Take the White/Red wire going to the ceiling light, splice into that wire and run a new wire towards the front of the car, where the maplight will be
-Split that wire into 2, either by soldering a "Y" or butt connecting a 2 wire split onto the wire you just ran.
-Connect the wires to one end of the spot lights
-Ground the other end of the spotlight with 2 seperate wires to a spot on the roof or a pillar
Old Feb 28, 2006 | 03:30 AM
Default Re: (dwolsten)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwolsten &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry to thread-jack, but do you have any threads about your carputer, your plans for it, etc.? I'm planning to do one as well, and your list of other plans actually corresponds to mine as well. I'm 100% complete on the parts for a HID retrofit (except I'm using Bosch bixenon projectors), but I haven't started on the carputer at all, and the K20 is still a dream.</TD></TR></TABLE>
Check out the link in my sig. I am documenting and updating it as I go. Maybe I'll even throw a page or two in for a map light retrofit...
808cuban
Mar 24, 2008 02:15 AM
jason DB8
May 4, 2006 04:25 PM
Mike1486
Sep 29, 2004 01:55 PM
racecarpete
Audio / Security / Video
Mar 27, 2003 11:30 AM
Eatvtec97
Apr 21, 2002 04:36 AM
