H22 Turbo HB
Well I currently have an 11 sec AWD DSM. Then a week or so ago I purchased a B20 Turbo Integra. Well I have decided to start a new project. I want real fast daily driver.
Today I just bought a Black 92 vx Hatchback for $2900. The car is in great cond and runs really well. I plan on starting the project asap and getting everything completed within a month or so. Here is the list
H22A swap
Inline Pro thick head gasket
Phantom Grip LSD
ACT Clutch
T3/T4 60-1 turbo set up
Spearco 2-120 FMIC
3" Turbo Back
450's, V-AFC, 255lph
Dyno Tuned with 15 psi
What am I missing from the set up?
What is the max boost and power the H22 can handle?
How fast are HB with similar set ups?
Any info you guys can give me would be great.
What am
H22A swap
Phantom Grip LSD
ACT Clutch
Spearco 2-120 FMIC
3" Turbo Back
What am
I also want to stay with the V-AFC as I already purchased it. Also once I get the car running with the motor/turbo swap I will do little things like the manifold, retainers, dual springs, big throttle body.
I will be running the car on slicks at the track and basically want to know what should be expected from a set up like this. I will be doing all the work custom. I am the owner of http://www.rnrracing.com and am excited about getting into Hondas.
Also what do I need to watch out for. Can I run 15-20 psi on this motor with the thick head gasket?
What H22 years came with the LSD. Also what year motors had the closed deck design?
The motors are that weak? The whole purpose of the build-up was that I didn't want to have to build the motor. I want/need to get the swap done asap adn don't have time to build the motor, plus the cost is a concern as I am trying to buy a new house right now. I didn't know the motor can't handle that much boost. What is the most you guys would recommend with the H22 and thick gasket?
Can the B18 handle boost better than the H22?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RnR Racing »</TD></TR><TR><TD CLASS="quote">Well I currently have an 11 sec AWD DSM. Then a week or so ago I purchased a B20 Turbo Integra. Well I have decided to start a new project. I want real fast daily driver.
H22A swap
Phantom Grip LSD
ACT Clutch
Spearco 2-120 FMIC
3" Turbo Back
What am
when you call inline for your headgasket, ask them about pat and mikes turbo h22 hatch. gutted, it went mid tens. stock block, afc, headgasket, 440's, walbro 255 intank. they can help you put it together. with race gas, decent tuning, and approx street weight of 2400 lbs, expect to run low 11's.
H22A swap
Phantom Grip LSD
ACT Clutch
Spearco 2-120 FMIC
3" Turbo Back
What am
