which mod next??
Old Apr 11, 2003 | 01:35 PM
gribbs's Avatar
Default which mod next??
For those of you who had i/h/e/, what was your next engine mod? the possibilities are many so I thought I would see what some people are going with.
Old Apr 11, 2003 | 01:37 PM
DR3AM's Avatar
Default Re: which mod next?? (gribbsEG8)
If you haven't already, I'd complete your exhaust system with a Hi Flow Catalytic Converter - e.g. CarSound Cat.
Easy mod and it'll free up your exhaust more.
Old Apr 11, 2003 | 01:45 PM
neo1z's Avatar
Default Re: which mod next?? (Gizzzer98)
I chose cams (after cat)
Old Apr 11, 2003 | 02:17 PM
BigMikeyStyle's Avatar
i'd save up for some skunk stage 1's with cam gears
Old Apr 11, 2003 | 03:10 PM
UnionCity LS's Avatar
Default Re: which mod next?? (BigMikeyStyle)
pulleys...but cams sound nice...
Old Apr 11, 2003 | 03:13 PM
threatcon13's Avatar
New User
Default Re: which mod next?? (UnionCity LS)
cams...toda A, with toda cam gears. (cat first)
Old Apr 11, 2003 | 03:33 PM
B00ST2nR's Avatar
Default Re: which mod next?? (Threatcon13)
Cat. convertor to free up the exhaust part, then Cams.
I went Cams and Cam gears first, and I'm suffering now with my stock Cat.
Old Apr 11, 2003 | 03:44 PM
95GSRVtec
Guest
Posts: n/a
Default Re: which mod next?? (Skunk2nR)
Cams for sure but it depends how your clutch is doing also!! If you feel like your clutch is on its way out i might wanna change that and the flywheel 1st!
Old Apr 11, 2003 | 03:47 PM
M-Type's Avatar
Default Re: which mod next?? (95GSRVtec)
cams would be good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRVtec &raquo;</TD></TR><TR><TD CLASS="quote">Cams for sure but it depends how your clutch is doing also!! If you feel like your clutch is on its way out i might wanna change that and the flywheel 1st! </TD></TR></TABLE>
yea if your clutch is going save about a grand for light flywheel and preformance clutch
Old Apr 11, 2003 | 03:49 PM
VTECorona's Avatar
Default Re: which mod next?? (M-Type)
cams
Old Apr 11, 2003 | 03:53 PM
95GSRVtec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M-Type &raquo;</TD></TR><TR><TD CLASS="quote">cams would be good
yea if your clutch is going save about a grand for light flywheel and preformance clutch</TD></TR></TABLE>
A $1000 for flywheel & clutch?????? This might be just a lucky guess but are you a TODA *****
Rguy
Sep 11, 2004 07:24 AM
GreenR
Aug 9, 2003 03:51 AM
Mover
Dec 25, 2002 02:08 PM
