skunk2 manifold with stock throttle bdy
Old Apr 11, 2003 | 08:52 AM
DOHCon15s's Avatar
Default skunk2 manifold with stock throttle bdy
If I run my stock throttle body on my skunk2 manifold would i loose power or should i bore it out. I know this is a dumb question but i dont know the answer.
Old Apr 11, 2003 | 08:55 AM
95GSRVtec
Guest
Posts: n/a
Default Re: skunk2 manifold with stock throttle bdy (DOHCon15s)
Its a good idea to atleast upgrade to a Type R TB to get a little more gains from the IM!! My personal prefrence would maybe invest in a spoon TB!! It gives a 70mm diameter than tapers down to 62mm to give some great throttle respnose!!
Old Apr 11, 2003 | 10:45 AM
neo1z's Avatar
Default Re: skunk2 manifold with stock throttle bdy (95GSRVtec)
I matched an ITR TB to my Skunk2 Manifold and I really think it helped out my dyno numbers - and throttle response is quite good in comparison to the stock TB.
Old Apr 11, 2003 | 10:55 AM
26R's Avatar
26R
Default Re: skunk2 manifold with stock throttle bdy (neo1z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">I matched an ITR TB to my Skunk2 Manifold and I really think it helped out my dyno numbers - and throttle response is quite good in comparison to the stock TB.</TD></TR></TABLE>
I also did this and agree. Throttle responce was much improved. I couldn't go back to that 58mm stock tb.
Old Apr 11, 2003 | 10:58 AM
StinkyTofu's Avatar
Default Re: skunk2 manifold with stock throttle bdy (SkunkdGS-R)
I thought gsr throttle body was 60mm and the type r was 62mm? Many people i have talked to with bigger throttle bodies say it just gives better throttle response. I'm looking at the erick's racing throttle body, but the smallest they have is a 68mm tapered to 66mm. I believe the opening on the skunk2 manifold is 62mm? Would this cause any problem or render the mod useless?
Old Apr 11, 2003 | 11:06 AM
95GSRVtec
Guest
Posts: n/a
Default Re: skunk2 manifold with stock throttle bdy (StinkyTofu)
I would like to also add for the peeps that upgrading to SKUNK2 Im for the GSR you will have to be using a Type R intake!! In most cases ex. AEM Type R intake has a 3in diameter which is much bigger and really needs a largert TB to utilize its full potential!! Just some usefull info im throwing out there!! I dont think anybody wants to be sucking air from a 3in intake into a 60mm TB then into a 62mm IM!!
Old Apr 11, 2003 | 11:14 AM
WorkForHonda's Avatar
how much for the spoon tb tho?
Old Apr 11, 2003 | 11:24 AM
nadc2's Avatar
Default Re: skunk2 manifold with stock throttle bdy (WorkForHonda)
It would be cheaper to just bore out your stock gsr tb to 62-64mm
Old Apr 11, 2003 | 12:30 PM
neo1z's Avatar
Default Re: skunk2 manifold with stock throttle bdy (HecticRhythms)
Stock GSR TB is 60mm.
Old Apr 11, 2003 | 12:31 PM
allmotorls95's Avatar
fyi the skunk manifold is 64mm
Old Apr 11, 2003 | 12:32 PM
neo1z's Avatar
Default Re: skunk2 manifold with stock throttle bdy (allmotorls95)
The Skunk2 IM is 62mm. Same as ITR.
SI BOII
Feb 19, 2007 06:23 AM
McFlurry
Jul 6, 2006 05:31 PM
asefi944
Apr 11, 2005 09:43 PM
PearlCrx
Dec 20, 2003 12:41 PM
JM Performance
Jul 23, 2002 05:24 PM
