Two different type of wheel lugs?
Old Apr 11, 2003 | 07:44 AM
Nuts's Avatar
Default Two different type of wheel lugs?
I remember there is a thread awhile back talked about 2 different types of lugs. One being more narrow and the other is rounded. I did a search with no luck. Can someone explain (or a link to the thread) what's the different?
I am getting a set of RH CP035, just wondering if the stock lugs would work fine with the wheels or would I need to get another set.
thanks,
CS
Old Apr 11, 2003 | 07:47 AM
JeffS's Avatar
Default Re: Two different type of wheel lugs? (CS)
http://tirerack.com/wheels/tech/nutsandbolts.htm
Stock uses an "acorn" shape, similar to the "ball/radius" pictured. Most aftermarket wheels require the use of a "conical" lug nut. Trying to use the stock nuts will prevent proper seating.
BlkChryKord
Acura TSX
Jun 3, 2007 04:51 PM
importdreamer
Nov 10, 2004 09:52 AM
cubism
Sep 13, 2004 01:17 AM
00R101
May 1, 2004 04:52 AM
REVolution
Dec 10, 2001 05:12 PM
