Splicing wires for a tachometer? How to!?
Old Apr 11, 2003 | 06:54 AM
GroundZer0's Avatar
Default Splicing wires for a tachometer? How to!?
How would i go about splicing the blue wire in this pic so that i can hook up a tachometer?
Thank you.
Old Apr 11, 2003 | 06:58 AM
Ef Whore's Avatar
Default Re: Splicing wires for a tachometer? How to!? (GroundZer0)
Get your splicers out. Make 2 cuts an 1/8" apart, slice the little piece in between the 2 cuts with a razor, remove the piece, splice your green wire on. Or you can do what I did and to to Radioshack and get the inline connectors.
Old Apr 11, 2003 | 07:08 AM
ATS_Antone's Avatar
do your splice up near the cluster its 100% cleaner looking. Gets rid of the wire running from the dizzy up to your tach =cleaner engine bay.
Old Apr 11, 2003 | 07:15 AM
GroundZer0's Avatar
Default Re: Splicing wires for a tachometer? How to!? (antone)
So wait, I can splice the wire right up near the cluster instead of in the engine bay? That may be easier. Is the wire the same color.. blue near the guage cluster?
Old Apr 11, 2003 | 07:22 AM
Ef Whore's Avatar
Yeah but it is way more accurate run right off the dizzy. Just hide it real nice.
Old Apr 11, 2003 | 07:25 AM
GroundZer0's Avatar
Default Re: Splicing wires for a tachometer? How to!? (Ef *****)
So i splice the wire going into the plug correct? Thanks
Old Apr 11, 2003 | 07:29 AM
CimorelliCRX's Avatar
Just get one of those connectors, where you put the wire in, and you snap it OVER hte existing wire, that way there is no cutting or anything, looks good, and works great.
Old Apr 11, 2003 | 07:32 AM
GroundZer0's Avatar
Default Re: Splicing wires for a tachometer? How to!? (CimorelliCRX)
Do you know if thats what the guy above was talking about, and "inline connector?"
Old Apr 11, 2003 | 07:36 AM
-slow ej-'s Avatar
yea its called a inline connector they make ur work much much easier
Old Apr 11, 2003 | 07:59 AM
pokemon's Avatar
Default Re: (-RsINtEg-)
"scotch locks"
Old Apr 11, 2003 | 08:02 AM
GroundZer0's Avatar
Default Re: (pokemon)
Thanks a ton guys! Also, how/where should i try to put the wires through thr firewall for an easy no cutting knuckles installation? Thanks!
kseriesdreams
Dec 26, 2010 04:56 PM
jareddx
Mar 4, 2010 06:59 AM
91rexhf
Feb 11, 2009 10:25 AM
tanabe
Oct 14, 2006 02:18 AM
91civichatchCrX
11
Mar 19, 2006 08:53 PM
